Old 03-30-2009, 09:55 AM   #1
BruthaMan
US Army Veteran
BruthaMan's Avatar
Gear Swap on 12 Bolt Axle
Hey Guys,
Been checking out some gear swap threads this morning, but unable to find an answer to some questions I have.
I have a 12 bolt axle on my 78 SWB with 2:73 gears. We pulled the cover off to check. I'm not very familiar with axles, but trying to determine what I'll need to swap out gears.
I want to go to a 3:73 setup (700r4 going in). I've seen mention somewhere before about swapping "carriers." Would that be necessary with what I have? Or do I just purchase the gears and have the shop do the work?
Also, how do I tell if it has posi-traction? Is that something I can check with the cover off?
Thanks for your advice!
BruthaMan is offline   Reply With Quote
Old 03-30-2009, 10:25 AM   #2
Adams74Chevy
Adams74Chevy's Avatar
Re: Gear Swap on 12 Bolt Axle
Originally Posted by BruthaMan View Post
Also, how do I tell if it has posi-traction? Is that something I can check with the cover off?...
The easiest way to tell is have the wheels off the ground, have a buddy hold one wheel while you turn the other, if it's posi it should make you buddy's wheel turn the same direction you are turning yours.
Adams74Chevy is offline   Reply With Quote
Old 03-30-2009, 10:34 AM   #3
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Take a look here for a breakdown of parts on a 12 bolt truck axle
http://www.ringpinion.com/PartCats.a...fName=GM%2012T
You should find pictures on the site that show you both open carriers and posi units
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 03-30-2009, 10:58 AM   #4
BruthaMan
US Army Veteran
BruthaMan's Avatar
Thanks guys, that helps a lot!
One last question. What's the highest gear I can run in a case for a 2:73 gear ratio? I think I read somewhere that with that setup, the highest you can go without swapping out the "carrier" (not sure that's right terminology) is a 3:42.
