View Poll Results: poly or oem rubber body mounts | |||
poly mounts, hard like rock. |
12 | 60.00% |
rubber mounts, lasted long enough. |
8 | 40.00% |
Voters: 20. You may not vote on this poll |
urban fourwheelin
poly vs. oem rubber mounts.
I want to here from you guys that replaced your body mounts. Did you use poly or oem rubber? if you had to do it again would you make the same choice? Do you wish you had gone with rubber or vice versa?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
Re: poly vs. oem rubber mounts.
Really like my new polys...feels firmer and last longer haha
71 ![]() |
installed poly back in 94
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Im afraid of purple hangers..
Ok so its 1987 and we are in new york building an old NESEG truck into a 4x4. We didnt have the money at the time. So we had Hockey pucks laying around. Hmmmm Body mounts drill and insert. They lasted 4 years.
I try it a few years ago and they lasted 6 months. So i installed Poly and they have been in for along time now. Its all in what you want to do? |
urban fourwheelin
this thing will not be wheeled hard. Mostly snowy logging roads and the occasional mud pit. Imagine it's 1972 and you are outfitting your new Blazer. i'm going to go with skinny tall tires. I don't want it to ride hard.
Also I should mention I have the poly kit already, but it doesn't have bolts.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 03-30-2009 at 03:56 PM. |
#6 | |
sounds sweet |
SKINNY TIRES RULE!
I've heard positives about both. Personally, I'd probably go with the rubber to help smooth the ride as much as possible since I won't be wheeling. If I was building a crazy, hard-core machine like Burt's, I'd probably install the tougher poly mounts. I've also read here on the board you need to coat the poly mounts with something to stop them from squeeking
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Poly-Sqeeke
I have heard about it but never heard it ![]() The main reason is the EnergySuspension poly I bought (black) were impregnated (sp?) some king of poplygraphite..I would have to look it up to get the proper term, some kind of anti-squeeke process Energy Suspension does. I think the red color is pure poly and may be the source of sqeekey mounts.
sharp as a marble
![]() Join Date: Jan 2007
I agree with Bouncy, I do not like poly anything. The rubber mounts work just fine, and allow someone else to wonder what that noise ( suspension bushings ) or what that vibration is. I want a Blazer/C-10 that drives like my wifes new Lexus, not like a race car. Ok, so I am dreaming a bit, but you get the picture.
Workin to live...
If you go poly, you must grease them before installing, or they WILL squeak! But they will firm up the body mounts!
Jason |
Factory replacement rubber mounts are a much better fit IMO, made to fit the application.
A lot of the poly sets I've seen are thinner and more generic, I've used em but won't ever again after seeing/installing the last rubber set. ![]() |
I'm a poor spectator
Good to know, too bad I already installed the energy suspension poly's.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#13 | |
Do you know what brand polys you were running? The energy suspension ones sound to be good. Perhaps you got different ones that weren't as good? |
![]() Join Date: Feb 2007
Jtrux- how did your install go? did you experience any of the issues VTblaze mentioned?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#15 |
I also installed energy suspension Poly in my Blazer and I haven't been able to drive it much but fitment was perfect and I've heard no squeeks.
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
#16 |
urban fourwheelin
I was waiting for VT to chime in.
my buddy offered to buy the poly mount kit, so I ordered rubber today from GMCpauls.
#17 |
poly is fine for body but go rubber for the springs. they allow for more flex. even on old snowy logging roads that little extra helps.
duct tape+bailing wire = trail fix if it aint broke it will be ![]() whoa hillbilly ![]() |
