03-30-2009, 01:51 PM | #1 | |
454 MAKES IT ROAR
steering column diameter & spline count
Bought this from CPP http://cgi.ebay.com/ebaymotors/63-72...0744QQtcZphoto... And they have asked me this...."
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 03-30-2009 at 06:51 PM. |
03-30-2009, 04:01 PM | #2 |
454 MAKES IT ROAR
Re: steering column diameter & spline count
It's a 71 with power steering & tilt....are the splines in the rag joint?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
03-30-2009, 06:53 PM | #3 |
Restoration Virgin!
Hello Nigel,
I believe you'll have to remove the intermediate steering shaft to get your spline count...here's a pic of the intermediate shaft.....you'll need to count the splines on the steering column and the splines in the steering box....I think?!?!?...hope this kinda helps Mate!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
02-29-2020, 08:47 PM | #4 | |
I'm putting an early 70's G-Van column (3/4"-36 spline) into my 66 GMC. The Steering box in my 66 is a Sagainaw 808 (3/4" - 30 spline) out of a 79 C20. The intermediate shaft that came with the 79 looks just like yours, except it has a 1" DD at the top end of it, and a rag-joint coupling at the bottom end. Yours looks like it's 3/4" - 36 spline at the top, rag joint at the bottom? I really like that it's the collapsible style with the nylon pins. |
03-01-2020, 10:42 AM | #5 |
Old member
Here is my link to putting the tilt steering columns in my trucks. As stated 3/4" DD on the box end and 36 splines on the column end.
http://67-72chevytrucks.com/vboard/s...d.php?t=799703 Here is what I bought for the ramp truck. Ensun 3/4"-36 Spline x 3/4" DD Nickel Plating Single Steering Universal U-Joint, Maximum Working Angle: 35° Degree, Total Length: 83mm (3-1/4")
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-30-2009, 06:56 PM | #6 |
454 MAKES IT ROAR
Thanks Geoff....your a pal. So is the intermediate shaft the flat sided one or is it the one that you have indicated in the second pic? I'm really dumb on this stuff.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 03-30-2009 at 07:06 PM. |
03-30-2009, 07:19 PM | #7 |
Restoration Virgin!
Sorry Nigel....I meant to say...The intermediate shaft connects the steering column to the power steering box (so it's the whole shaft shown in pic 1)....So you would need to remove the rag joint at the pwr steering box first, then back the bolt off the collar at the steering column (as seen in the second pic) to remove....you'll need to wiggle it off....be patient!HA
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 03-30-2009 at 07:21 PM. |
03-30-2009, 07:32 PM | #8 |
454 MAKES IT ROAR
Ok! I understand it better now. Getting that question from CPP threw me, the way they advertise it I thought it fit right on there...silly me for thinking things were that easy.
Thanks for your help mate.
03-30-2009, 07:39 PM | #9 |
Restoration Virgin!
Nigel,
I'd recommend getting a Factory Assembly manual too it looks like this....it runs $35-$40.....check with Wes I think he has some.... It has some very detail assembly pics that helped me out tremedously throughout my build!!! By the way, how'd your transmission fix turn out??
03-30-2009, 08:08 PM | #10 |
454 MAKES IT ROAR
I'll pick one up.
Got the trans back the other day...going to update my original post and you can see how it came out. Basicly £400 on a general revamp of the Trans & £200 on a new Torque Converter which converts to about $850.
03-30-2009, 08:32 PM | #11 | |
TILT COLUMN GURU
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY Last edited by KevsClassics; 03-30-2009 at 08:33 PM. |
03-31-2009, 03:58 AM | #12 |
454 MAKES IT ROAR
Thank you Kev, i'm going to take it apart and have a look as well, it will need to come out in the end to fit the new one anyway.
