04-01-2009, 01:19 AM | #1 |
Driven a 72
Electrical Nightmare Please Help
Ive got a electrical nightmare, Ok so here are my symtoms.
Headlights on blinkers wont work at all. Headlights off blinkers work but both rear blinkers blink. Step on brakes with lights off and dash lights light up. Any suggestions?
1996 GMC JIMMY 1972 CHEVY C10 LWB My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729 |
04-01-2009, 01:32 AM | #2 |
Re: Electrical Nightmare Please Help
Time to check all the grounds,and check all the wires for shorts, but i would make sure all the grounds are good first,bad grounding can cause some funny things to happen.
04-01-2009, 01:39 AM | #3 |
It does sound like a ground problem with the taillights.
One more thing to check that tends to cause problems on these trucks is a cobbled up trailer wire connection that someone put on at one time or another. Those can be a prime source of shorts and messed up connections if they were not done right. |
04-01-2009, 01:59 AM | #4 | |
04-01-2009, 05:36 AM | #5 |
its all about the +6 inches
i would start off with new bulbs and checking the grounds
04-01-2009, 05:55 AM | #6 |
Driven a 72
Thanks all I will post up some pics of the mess that is in the back. I think it may be a trailer light setup. Also does the engine have to be grounded to the firewall or can it be the frame?
04-01-2009, 01:11 PM | #7 |
I had similar issues when installing a new Painless harness. Turned out to be ground issues. I grounded 4 places: engine-chasis, engine-frame, chasis-frame, bed-frame. All with braided straps, cleaneaned to bare metal and coated with dielectric grease. No problems now.
04-01-2009, 01:19 PM | #8 |
Project Junkie! Fishing Poor!!
Sounds like the headlight switch has failed and you are getting electrical feedback through it once you turn your headlights on. Replace the switch and also check your grounds like everybody else says. I had a simeler problem on the Blazer that is in my shop now, but the new headlight switch solved it. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-02-2009, 03:17 PM | #9 | |
Good luck... |
04-01-2009, 02:16 PM | #10 | |
Driven a 72
04-01-2009, 03:16 PM | #11 |
Yes you need ground straps from the frame to body and motor to body,or else the only ground path is through the body mounts and that is not a good ground path.
04-02-2009, 09:04 AM | #12 |
On mine, the engine-chasis was on the p/s cylinder head to a large machine screw on the firewall. The Chasis-frame strap went from the p/s fwd cab support to a hole in the top of the frame.
