Old 04-01-2009, 04:29 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Steering column parts?
Who makes ALL of the steering column parts? To start my 84 I put the key in, turn it all the way, then pull the rod on the left to start it. The PO screwed up the column, he broke the collar, the gear shift has to get pull past the wheel to put it in gear, he broke a piece on the top of the rod that goes from top to bottom on the left side of the column. Also, would it just be easier to get a new column? Mine has tilt, also has (cruise, blinker, and wipers all on one switch), and is auto on the column.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 04-01-2009, 04:37 PM   #2
impalamark
impalamark's Avatar
Re: Steering column parts?
I'd go for a new/used one easy to come by under $100 as low as $30 fairly easy to swap
not a bad a do it yourself at all
Mark
the avatar was my 62 I owned for 27 years
84 chevy short short bed black
84 gmc long bed copper/ buckskin
88 chevy k5 blazer white
Life's short make the most of it
Mark aka impalmark
impalamark is offline   Reply With Quote
Old 04-01-2009, 04:46 PM   #3
thirdstreettito
Resident of Here
Who makes new ones?
~Bradley~
Miss having a truck
Old 04-01-2009, 05:39 PM   #4
JohnC
JohnC's Avatar
You can get aftermarket ones from like Flaming River. Other than that you may check in your local area for someone that rebuilds them. Talk to the salvage yards. Sometimes they will hold some for the people that rebuild them. They may be able to give you a name of someone in your area.
JohnC is offline   Reply With Quote
