Leaf Spring Drop???
How do you drop a leaf spring truck, without doing a coil swap? Anyone used the drop springs from Early classic Enterprises~http://www.earlyclassic.com/?
Can you take individual leaf's out or is that not a good idea? Any Pics guys?
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
![]() Join Date: Jun 2007
Re: Leaf Spring Drop???
Not a good idea to take out leafs, as it could possible buckle in the rear.
DJM Suspension makes an axle flip kit for these. 5" in the rear and you can go to 6" with a 1" lowering block or 7" with a 2" block. http://www.stylintrucks.com/parts.as...tfamilyid=3339 |
Thanks MonteSS454, Anyone else?
resident oilfield trash
How far do you want to go. They are pretty simple just a lot more work than the coil drops.let me know how far and I will tell you what you need
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
I don't really know maybe 4 or 5
4 is a more difficult drop than 5. 5 is easy it is a simple flip. 4 you will need shackles and hangers and if they are riveted to the frame they are not much fun but the shackles are easy. Good thing about these trucks is you don't have a gas tank to fight with when changing out your hangers.
http://cgi.ebay.com/ebaymotors/70-72...3A1|240%3A1318
Tad bit cheaper. If you end up with this kit let me know how the install goes. I've just been putting off buying it. Last edited by MonteSS454; 04-02-2009 at 12:36 AM. |
#8 | |
Basically put the axle on the leafs, with the right hardware anyways
Yeah, do u think that'd be easier than buying and installing the drop leaf's, I know it would probably be cheaper.
Leafs are a pain to mess with when the aren't bolted in. Took me and another buddy (About 350lb total) to get one of my leafs back into place after changing a shackle.
A good friend of mine took out every other leaf then proceeded to put a pumped up 454 in and run low 11s at the track in a 70 lwb without the springs giving him any trouble with buckling or breaking if anything the added flex improved the ride and helped it hook up.... just something to think about if your budgets as tight as mine right now.
Active Member
![]() Join Date: Feb 2009
I notice the kits described in the links above specify 1/2 ton. What about 3/4 ton ? I have a nice 3/4 ton 72 Sierra that would look really good if it's tail wasn't 3 feet off the ground.
Papa Smurf
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
#14 | |
Moderator
![]() Join Date: May 2007
#15 |
![]() Join Date: Mar 2007
My truck was done by PO. Its leafs. Flipped axle on top and c-notched. Works great but rides rough.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
#16 |
Your front end needs to come down a little bit
#17 |
I don't think there would be much differences in the 2 rear ends, same axle housing sizes, leafs, etc......Maybe someone else can chime in on this one.
#18 |
![]() Join Date: Jan 2008
flip the axle and take out a leaf or two if its too high. Ive done several that way without a problem.
