Old 04-02-2009, 07:38 PM   #1
Grapdawg
Driven a 72
Grapdawg's Avatar
Drive it or not. What do ya think
Well got my truck put back together for the most part so my body guy can finish the box and I want to drive it to work tomarrow. It is running pretty good, But I havnt drove it more than 20 miles since i got it and it has been sitting for nearly 3 years. Its got a pretty tired 307 in it that hasnt leaked a drop in my garage since Ive had it. Im just alittle unsure about drivin it on the highway. I think if I keep her around 55-60 it will be fine but I guess ya never know. Anyone have any storys or thoughts on the matter.
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
Old 04-02-2009, 07:47 PM   #2
68_Bowtie
68_Bowtie's Avatar
Re: Drive it or not. What do ya think
My thoughts..... Go for it, it's a Chevrolet ain't it ?
As long as you check all the fluids, you'll be fine.
68' SWB 355 CID since 1987
89' S15 4WD 4.3
08' VTX 1300R
08' Chevrolet HHR (Wife's ride)
"That man right there is the best sprint car driver in the whole ---damned country!" 1974- Indianapolis- AJ Foyt pointing out Jan Opperman in the garage.
68_Bowtie is offline   Reply With Quote
Old 04-02-2009, 07:48 PM   #3
sjarrett71
sjarrett71's Avatar
If it hasn't leaked I would make sure there are fluids in it!
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-02-2009, 07:51 PM   #4
Grapdawg
Driven a 72
Grapdawg's Avatar
Yea Your right it is a chevy, And sjarrett71 thats funny Yes I changed it my self. Its probly the inch of grease on the oil pan that is keepin it sealed.
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-02-2009, 07:56 PM   #5
vectorit
What?
vectorit's Avatar
Make sure the tires are not to badly dry rotted.
Plus check for tools hiddden about the truck!
When I took my burb out for the first time, after spending a long time in the garage. I drove down the street, and I heard a few things metal hitting the road. Went back and found a few wrenches laying on the street!
Also, make sure all the hose clamps are tight. Sometimes they don't get tightened down as they should after putting everything together, since sometimes you will put them in their place while working on other stuff to get them out of the way. Thus forgetting that they are just slipped on, and not secured. So, run it around locally for a while getting it up to normal operating temps. If there is one, it will pop off and shower your engine compartment with dirty water/antifreeze. Better to find this close to home if it does happen, rather than on the highway on the way to work in the morning.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-02-2009, 08:03 PM   #6
Grapdawg
Driven a 72
Grapdawg's Avatar
Great points. I have driven it and got her up to operating temp. But I think Im gunna go around tonight and tighten everything once more for peice of mind. Good thing my foreman is a motor head and will be following in my same path so he could stop and help me on his way if something did go wrong. If I get on the road before him.
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-02-2009, 08:07 PM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
take her out and beat it like a red headed step child..if you have gas,oil and the rad holds water it'll run 20 miles besides it's friday if you break down you have all weekend to get it fixed and try again monday.
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-02-2009, 08:07 PM   #8
69halfton
69halfton's Avatar
if you check it all over tonight, and make sure everything is in good, working order, i would not be worried about it. keep an eye on temps & oil pressure and other vital things like that
i had a brand new engine & transmission built, dropped it in, set the timing, and drive it to my cottage (about 130 miles or so)
and for all of you who ask, its roller cam & rockers so the only thing to break in are the rings, and they got broken on the way as there is no interstates here, just two lane roads in and out of towns. (I.E no sustained rpms, up and down constantly)
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 04-02-2009, 08:15 PM   #9
Grapdawg
Driven a 72
Grapdawg's Avatar
I knew I could count on all ya guys for some positive feedback. This site is the best thing since beer.
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-02-2009, 09:16 PM   #10
Boog
laying low
Boog's Avatar
Take a look at the belts. And take a few basic hand tools along too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-02-2009, 09:13 PM   #11
texanidiot25
Eat My Rust
texanidiot25's Avatar
Fuel filters, rags, and any tools you need to swap fuel filters. If it's been sitting, the highway is the perfect time for it to suck up any rust build up in the tank and wash it into the carb
Been there, done that. If you have a q-jet, don't even bother using it's filter if you start having clogging problems, it takes no time to clog (No capacity towards catching anything). Just buy a bunch of the $3 Fram ones from walmart and keep them handy.
texanidiot25 is offline   Reply With Quote
Old 04-02-2009, 09:32 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
drive it....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-02-2009, 09:42 PM   #13
OARNGESI
OARNGESI's Avatar
Go for it and tell us how it works and hoprefully you dont break down and get fired
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-02-2009, 10:04 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you'd have no problems callin in late or calling off, then go for it. If your boss would frown on it and hold it over your head, then hold off for a day and go on a 100 mile shakedown run saturday morning with a bunch of tools and fluids.
Old 04-02-2009, 10:12 PM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
I drove my truck around a lot locally before I ever hit the highway with it, especially after the 700R rebuild.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-02-2009, 10:58 PM   #16
russellmarling
russellmarling's Avatar
Brakes! Making sure its gonna stop is more important than making sure its gonna go... otherwise it may run great all the way to the scene of the accident...
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress)
'09 CTS-V M6
'03 Sierra SWB Z71
'82 Yamaha Seca XJ650R Turbo!
'04 Yamaha FZ6
russellmarling is offline   Reply With Quote
Old 04-03-2009, 12:40 AM   #17
Grapdawg
Driven a 72
Grapdawg's Avatar
Thanks guys for all the comments. Im going for it. I got my bag of tools some fluids and went over everything tonight. My foreman is the one who wants me to drive it in. He is a motor head and wants to see my progress. He is currently building a 55 chev tow truck and convertn it to a drager. Anyway I will fill ya in and thanks for all the positive comments and feedback. Well better get some sleep so i dont dose off on the way, HA.
Cheers.
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-03-2009, 06:39 PM   #18
Grapdawg
Driven a 72
Grapdawg's Avatar
Re: Drive it or not. Well I made it! But could of been better
Well I drove the truck to work today. about 70 miles round trip. Things went great this morning and the truck drove real nice, On the way home though the tired motor decided to start making some major lifter noise. It had some noise from the drivers side lifters before. but on the way home she really started to clatter, I was going about 60 most of the way but when ya kick it down a light cloud of smoke would appear. I was woundering if you all had any excperiance with noisy lifters and ever tried to tighten the rocker arms to cure the problem. I know the motor is very tired and I need a new one but was hoping to make it through the summer with this one. I was thinking of trying to tighten the noisy lifters. (Take of driverside valve cover and see what I can find with it running anb see if I cant get it to quite down) What do ya think?
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-03-2009, 06:48 PM   #19
Boog
laying low
Boog's Avatar
You might be able to help it a bit. Just slow the idle down real low and remove the valve cover. Loosen one at a time until it starts clacking then tighten until it stops then tighten an additional 1/2 to 3/4 turn. It should be good then.
Also note that a worn fuel pump sometimes makes the same clacking noise. Been there.
Boog
primer is finer
Old 04-03-2009, 06:50 PM   #20
Hottrucks
Hottrucks's Avatar
cann't hurt any and if your do to change the oil soon add a quart of tranny fluid t it.....the tranny fluid will soften up the old seals and flush the lifters out..don't be afraid to drive it around town 20 miles or so the drain it out hot
and let me be the first to give yea an ATTA BOY!!!!!!! drive it!!!!
Old 04-03-2009, 10:30 PM   #21
Longhorn Man
i don't advise running any kerosene or motor flush... it might help, or it might wipe a bearing, or it could knock some crap loose and clog up the oil pump pick up... seen too many engines die right after that. Working in a shop, we see them on a somewhat regular basis, they say the went to XYZ 30 second oil chainge place and got the "good oil chainge" that includes a flush, and there engine started knocking a day later.
I would adjust the rockers, chainge the oil and filter (esp if you haven't lately) and see what happens. it may be time for a new engine.
