04-05-2009, 10:29 PM | #1 |
"the other guy"
250 points to hei question
engine seems to run a little rough now? can i use the same plugs,and is the gap different between points and hei? also what is the base timing supposed to be?thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
04-05-2009, 10:41 PM | #2 |
Re: 250 points to hei question
I used the original base timing & plugs (set @ .035 gap).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-05-2009 at 10:42 PM. |
04-05-2009, 10:42 PM | #3 |
"the other guy"
whats the stock specs for timing?
04-05-2009, 11:23 PM | #4 |
Too Dumb To Know Better
Gap them to .045 or .050 and you'll have better luck. I think the timing is 6 or 8 degrees BTDC.
04-05-2009, 11:26 PM | #5 |
"the other guy"
"low'n slow" is the decal i just had made for my 67. thanks for the info
