Old 04-06-2009, 01:29 PM   #1
ashx2
Where does this belong?
I got this wire w/2 bulbs on it from a truck that I took some parts off of. I am assuming it's for illuminating the heater/ac controls or the floorboard area....but it's a dangerous thing to "assume" things, ya know?
Also, exactly where would this plug into the fuse box? An accessory spot or is there an actual spot for it?
If anyone has any input, it'd be appreciated.
Greg
ashx2 is offline   Reply With Quote
Old 04-06-2009, 02:04 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Where does this belong?
Okay, I'll bite.....courtesy lamps?
Member Nr. 2770
Old 04-06-2009, 02:10 PM   #3
hchad18
hchad18's Avatar
My 83 has a setup like that, except only one bulb and it illuminates the floorboard. It plugs in on a terminal in the back of the dash.
hchad18 is offline   Reply With Quote
Old 04-06-2009, 02:29 PM   #4
monte0185
monte0185's Avatar
License plate lights maybe?
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-06-2009, 02:33 PM   #5
ashx2
No, they came from inside of the cab. I undid the wiring that was pictured, and I was mistaken, it's not two bulbs on one line, each bulb has it's own wire. One had the plug and the other has been cut.
I think I will use them to illumiate the floorboard though and figure something else out for the heater/ac control.
Greg
Old 04-06-2009, 03:50 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
those are for the heater control panel on an A/C truck.
The stock 'as original' one wires in through the harness, but with that plug, you can plut it into the fuse block... I can't remember what the tab is marked, but it is right by the inst panel fuse, and the terminal is controlled through the rheostat on the headlight switch.
Old 04-06-2009, 05:10 PM   #7
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
A/C panel lights, one fits in the end closest to the driver the other on the side closest to the passenger.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 04-06-2009, 06:50 PM   #8
ashx2
So is there a socket that the bulb/housing fits into that makes a grounding connection? Or will the light function w/out being grounded?
If anyone has a pic of one of these bulbs installed, that would be a great help.
Thanks,
Greg
Old 04-06-2009, 06:56 PM   #9
68gmsee
Active Member
68gmsee's Avatar
If anyone has a pic of one of these bulbs installed, that would be a great help. Thanks, Greg
Those metal tabs around the bulb are the ground.
68gmsee is offline   Reply With Quote
Old 04-06-2009, 07:35 PM   #10
ashx2
Okay, so where do they fit into?
Thanks,
Greg
Old 04-06-2009, 07:59 PM   #11
Jim Osborne
On where it plugs,it has to plug in the dash light circuit,because if you plug it in to the fuse box it will work all the time you would think.
Jim Osborne is offline   Reply With Quote
Old 04-06-2009, 10:43 PM   #12
Longhorn Man
the tab on the fuse block is labeled cluster feed, it is controlled by the headlight switch, the bulb will come on and off, and dim, just like the dash lights. The terminal is there for this very reason.
The bulbs plug into the 2 holes on either end of the heater control panel on an A/C equipped truck, the lights will ground through the metal tabs on the sockets as seen in the photo, the tabs hold the assembly in place, and ground through the control panel.
Try it... it'll work.
Old 04-06-2009, 10:55 PM   #13
68gmsee
Active Member
68gmsee's Avatar
When you ask, "where does the bulb connect up to," are you wanting to know where the socket housing goes?
It will be a round hole the same diameter of the plastic housing. But since I don't have A/C on mine, I won't have the hole for it. Mine has a smaller bulb in a similar housing that plugs into a hole behind the heater/defrost controls.
Maybe someone else has a pic with the A/C one...
Old 04-07-2009, 12:27 AM   #14
ashx2
Yessireee, you're on the right track. I looked, but I didn't see a spot for them to plug into. I'll have to look again......a little better this time maybe.
Thanks,
Greg
Old 11-05-2012, 04:52 PM   #15
crzo68
crzo68's Avatar
can we still purchase this set up ?... my lights have been chopped up for an old aftermarket 3 gauge set up from the PO.
crzo68 is offline   Reply With Quote
Old 11-05-2012, 09:03 PM   #16
whoryou1979
whoryou1979's Avatar
The bulb sockets plug into the rear of the a/c heater control head. There is a hole on both sides and they will snap in.
All Day Every Day
'72 C20 Cheyenne Custom Camper
http://67-72chevytrucks.com/vboard/s...d.php?t=549132
whoryou1979 is offline   Reply With Quote
Old 11-05-2012, 09:50 PM   #17
CG
BlahBlahBlah
3.5 year old thread, I hope he got his bulbs figure out by now =)
As far as purchasing a set of these lights, watch the parts board.
Also, after reading the responses it reminds me how much the board (at least I do) misses Andy
Old 11-06-2012, 02:29 AM   #18
WIDESIDE72
WIDESIDE72's Avatar
What was andy's handle?
WIDESIDE72 is offline   Reply With Quote
Old 11-06-2012, 02:35 AM   #19
CG
BlahBlahBlah
longhorn man
I didnt mean that to sound like he has passed ... he just sort of retired from the board to be with his new family =)
