Old Heap Driver
Shocks for a bagged front end
What shocks are you guys with bags running on the front?
I've looked at drop shocks, building a new upper mount, etc. I've searched and read so much it's all running together. Help!! Thanks! Bryan
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Old Heap Driver
Re: Shocks for a bagged front end
Anyone?
One day...
You will have to find a shock that wont bottom out when aired out and that you wont pull the guts out of if you raise it all the way. you can use toxics or something like that, a friend of mine just uses monroes from local parts stores because they wont last as long compared to a factory suspension and they are easy to come by asap. Hope that helps a bit.
#4 | |
Old Heap Driver
Looks like building a new upper mount is the way to go.
#5 | |
One day...
#6 | |
Old Heap Driver
If I build an upper mount that raises the mounting point 3-4" I should be good with a stock over the counter shock.
Seņor Member
This would be a good opportunity to try out the search feature. There are a half dozen really informative threads on this very subject.
#8 | |
Old Heap Driver
Thanks for the suggestion though.
#9 | |
Seņor Member
#10 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
I have bell tech on mine
![]() XXL your attitude does suck...but I feel the same pain ![]() and I like the 'tude ![]() sorry for the hi-jack..............
Resistance is Futile
Well I'll throw ya off track.....I just picked up a bunch of budget S10 parts including an air set-up for the front. I asked the guy what he used for shocks and he said he didnt run any!!!!!!! 98 extended cab 4cyl.....I cant confirm it, but he didnt have any shock brackets in the stuff he sold.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I run nothing but Bilstein.
If you can find it cheaper, I can fix it! |
#15 |
I set my Beater up for Bilsteins (replacement fronts & 88-98 rears using modified brackets). I'm curious how you choose rear shocks for your builds w/air set-ups. Do you have a select p/n you like or ??
#16 |
Those are the air ride shocks I use.
I order my shocks based on length, weight of the vehicle, suspension type (IRS, straight axle, really heavy straight axle, etc), and the weight of the wheels.
#17 | |
IS there a book that list all the specs or just down at the auto parts store?
Adam M STX Designs Motorcycles | Choppers | Hotrods |
#18 |
Isnt there some bilsteins specifically for bagged trucks? All I could find searching the net was http://www.racecardynamics.com/class...ag/airride.htm
#19 |
Seņor Member
bump
#20 |
I am talking about the air ride shocks. I call RCD with the listed information, and they set me up with the correct shock.
#21 |
i just bagged my back end last weekend and had to find shocks.
instead of trying to guess what type of shocks you need before you do the upgrade, you should really bag it first and then get your aired out and max height distances. once you have that you can go to napa, or an autoparts store that hires knowledgable people and they can find you a shock that matches those specs. i paid $33/each for my rear sensatrac shocks. i searched and searched the forum like you and everyone else with no luck. chances are your setup will be a little different than others so you maybe wasting money trying to guess on a correct shock and hope it works. |
#22 |
Happy to be here
![]() Join Date: Mar 2000
Knock it off guys.
#23 |
![]() You guys run shocks on bagged trucks? Not me! Here's the deal, the back is bouncy, unless you ride at 1-2in off the ground then it's ok. I will be getting Monroes for the back asap. The front with the weight of the engine rides lots better than stock height with good shocks. I won't bother with front shocks, just back. 4-5 months and no shocks at all. |
#24 | |
Should it be done? No, it should not.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-21-2009 at 04:38 PM. |
#25 |
![]() get out the ruler and start smacking knuckles Ken! ![]()
![]() ![]() Last edited by joe231; 09-21-2009 at 04:15 PM. |
