Old 04-09-2009, 09:42 AM   #1
cochino12
It followed me home?
cochino12's Avatar
How much damage can dragging LCA's really cause?
Just curious what problems you all have had by your LCA's rubbing occasionally?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-09-2009, 10:52 AM   #2
Red_69
Red_69's Avatar
Re: How much damage can dragging LCA's really cause?
Just some minor chafing. Baby powder does wonders.
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 04-10-2009, 12:37 AM   #3
heavychevy79
Cheyenne Super
heavychevy79's Avatar
It's the headers I worry about. Are yours stock or tube?
Baby powder lol
heavychevy79 is offline   Reply With Quote
Old 04-10-2009, 12:44 AM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
do you mean rubbing the inner rim, or the ground
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-10-2009, 02:18 AM   #5
cochino12
cochino12's Avatar
I'll try it but I'm not sure if its going to work ha
They are long tube right not but I'll have that fixed here soon enough, so it wont be a problem
I mean rubbing on the ground
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 04-10-2009, 03:16 AM   #6
flamingbig10
6.0 powered square
Mine does it all the time, unless I completely stop over dips and large bumps , but then it makes the people behind me mad, I guess they don't under stand how low my truck really is, and one time I hit a bad patch job in the road and I thought I almost ripped the lower control arms off, but it was loose asphalt, so it just through a lot of the loose stuff under my truck
Aaron
Old 04-10-2009, 03:26 AM   #7
flamingbig10
6.0 powered square
Buddie of mine hit a bad pot hole and it tore the lca of the truck
Aaron
Old 04-10-2009, 01:02 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Get a visual of this, ok. Dragging along on asphalt wont do much damage.
Now imagine the stars are in alignment and you happen to dip at the same time you are crossing over a manhole cover. You know the ones that aren't "quite" flush with the road surface.
I'll let you do the math...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-10-2009, 01:17 PM   #9
LONGHAIR
Anything that hangs below the scrub-line is dangerous.....ever have a flat tire?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-10-2009, 01:22 PM   #10
OrangeAnimal
OrangeAnimal's Avatar
I wish I had pics of when my hondas lca came off. It was nasty. trashed a fender and alot of other stuff. The only thing that sorta held it together was the axle.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 04-10-2009, 06:26 PM   #11
dammitmitchell
the pollock
dammitmitchell's Avatar
scrub line?????
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-10-2009, 11:29 PM   #12
79Silv4x4
Workaholic
79Silv4x4's Avatar
Originally Posted by dammitmitchell View Post
scrub line?????
Here's an explanation I found online. . .
Scrub Line
Imagine your car-any car-sitting on the street without any tires. The wheels are still there, just without the rubber. Is anything touching the ground? Suspension parts, any brackets, exhaust system, fuel tank, transmission, or motor even? If so, they are below what is called the scrub line, and while you may not worry too much if those massive 6-inch lowering blocks meant the nuts on the U-bolts are now halfway down the sidewall of your rear tire, you'll be in for a nasty surprise if you get a flat on that tire at speed. Those U-bolts will make a nice gouge in the blacktop, and you'll be fighting to stay in control of the car ... if you're lucky. You'll more likely be in the ditch or facing oncoming traffic. Tall tires don't help either, but ensure no part of your undercarriage hangs down below an imaginary line drawn between the bottom of all four rims. In fact, an inch of clearance would be a good idea.
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 04-11-2009, 05:54 PM   #13
dammitmitchell
the pollock
holy crap finally a "real reason" for having big rims he he he
Army vet 02-08
