Old 04-09-2009, 12:04 PM   #1
Houston54
C3 Vette (68-82) Rear Suspension into Task Force
I have found information on kits to install C4 series vette IRS units into Task Force trucks but am looking for information on installing an IRS from a C3 series. So far I am not finding much.
Has anyone used this unit on their 55-59?
Is there something regarding this IRS that limits its use for this application?
The reason I am asking is I have access to a 78 vette IRS at a good price and think it would be good under the 58 currently waiting for garage space.
Houston54 is offline   Reply With Quote
Old 04-10-2009, 08:51 AM   #2
Bob@ProAuto
Re: C3 Vette (68-82) Rear Suspension into Task Force
The 1963-79 & 80-82 Corvette rear ends are 57.5" hub width. The deepest backspaced wheel (when talking 15") is 4". You would have to tub the bedsides for tire clearance.
Bob@ProAuto is offline   Reply With Quote
Old 04-11-2009, 07:03 PM   #3
cajundragger
so your saying its too narrow or too wide?
cajundragger is offline   Reply With Quote
Old 04-13-2009, 07:04 AM   #4
Bob@ProAuto
Typical bed side to side on these is 50.5" wide. I personally think it's too narrow.
Old 04-13-2009, 07:51 AM   #5
Houston54
I have decided to pass on this C3 unit as it just does not work well with the Task Force chassis. It also does not seem to fit well with the AD series chassis either but I am sure if someone wanted to use it they could find a way.
The C4 series suspension is a better option for my needs. Now I just have to have one fall into my lap like the C3 did.
Old 04-13-2009, 09:49 AM   #6
robin58
Depending on your definition of a good deal, Dino's in Picayune, MS sometimes has reasonable deals depending on supply/demand (they're a Vette only junkyard / parts supplier). There's also a listing in Hemmings Motor News right now for a front and rear from a 84-87 C4 ($750 each). Little pricey for the front imho but not bad for the rear.
robin58 is offline   Reply With Quote
Old 04-13-2009, 03:43 PM   #7
57ExtCab
84's should go for alot less I know on the TRI cars you were limited to on brake and wheel options; There was a time when you almost had to give away that 84
Then again the Wife could be RIGHT
"Just cause I Drink alot of Bud that does'nt make me WISER"
57ExtCab is offline   Reply With Quote
Old 04-13-2009, 06:52 PM   #8
Coronas56
Coronas56's Avatar
Say I got my C4 Vette from Red line corvette in Calif. for $1.200.00 Shipped, it was from a 96............Front and rear
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 04-14-2009, 07:30 AM   #9
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Here are some pic's from a show in GA in '98. The Vette IRS was installed by Mike Chesser, he did the Camaro clip on my 57. I think he sells a kit for the Vette install.
http://www.chesserbuilt.com/
ChuckDriver is offline   Reply With Quote
Old 04-14-2009, 07:58 AM   #10
Houston54
Thank you for the pics. I have sent them an email requesting some additional information on this installation. With the 57.5" hub to hub width what tire size/rim backspacing did you wind up using to keep the rubber off the bed sides?
