Old 04-10-2009, 05:26 PM   #1
nicks05z71
nicks05z71's Avatar
'68 on bags, "Shop Truck"
Finaly its been nice out and I've had time to start this project. As of right now I'm going to be keeping the stock v8 and 3speed w/overdrive. (Actualy ran the numbers on the block and found out that its not a stock 307, but an '80s 305).
As far a suspension, I have 4 D2600 w/ SD's front plates and cups. ECE's super track bar and shock relocator. Need to get drop spindles and disk brakes yet, and I have the steel to make 2'' blocks. I need to call SD up and order some valves/tank and such. I also had a guy give me a York 210.
Took the bed off to start on the back. started by taking the shocks off and cuttin rivits for shock mounts and bump stops. After that I got the spring out and bags mounted/w tep. air lines so I can move it around. Keep in mine nothings painted, and I have to go over everything agian, but this is where im at now.
Started with
frame rails are on the axle tubes! Next nice day Im going to work on the track bar and shock relocators.
nicks05z71 is offline   Reply With Quote
Old 04-15-2009, 06:20 PM   #2
nicks05z71
nicks05z71's Avatar
Re: '68 on bags, "Shop Truck"
Well its been raining for about 2 days now so I havent had a nice day to work on work on my super track bar or the shock relocators. Since I had the stock to make blocks I thought I would use a friends mill and put holes in them! Started by cutting the stock to lenght (used the spacer from my ECE track bar as a templet). Located my holes and started drilling. Started with a 1/4'', then 1/2'', finaly an 7/8'' end mill. The U-bolts that come with the ECE track bar are longer than stock, but dont look long enough for much of a block, so I got new U-bolts from the spring shop that are extra long. Since everyone likes pics..........
Setting up the mill after I cut the stock the length
Using the 7/8'' end mill.
Done!
On a side note, I was at a swap meet last weekend and found a new viair 480 and only payed $100! Came with an viair gauge, little bit of 1/2'' and 1/4'' air line, the filter and extra foam for the filter!
Also ordered the viair 3/8 starter kit from SD. So I can start to mount my tank and valves while the beds off.
Old 04-15-2009, 06:33 PM   #3
nicks05z71
nicks05z71's Avatar
Also I have some questions. I know I've seen a thread with this in it but I cant seem to find it.
Would it be a big deal to mount the 480 and 380 on the same tank? I want to wire it up so i can run one or both, so when my tank is really low I could have faster fill times, and when Im at presure I could shut one off. This would also act as a backup if anything should happen to one comp.
Another question.
Below the axle I have wedges. (correct the angle?) Is everyone putting these back in? I just dont like the fact that I would have to stack 10 things under the axle.....axle tube, track bar, block, wedge....you get the idea.
Old 06-16-2009, 01:33 AM   #4
nicks05z71
nicks05z71's Avatar
Been awile since I've updated this. I've been working on the tank and valves, wiring and plumbing.
I took my tees and drilled and taped 1/8NPT for gauges. I've used locktite 545 on everything. all parker PTC DOT fittings.
found some Monster brand 9 wire for the valves, should be here in soon and ill start workin on the wiring. Havent done anything to the front yet.
Old 06-16-2009, 08:30 AM   #5
mycool72
mycool72's Avatar
looks good!
mycool72 is offline   Reply With Quote
Old 06-16-2009, 10:59 AM   #6
bigguy69
dazed and confused
bigguy69's Avatar
i like it. keep up the work.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 06-16-2009, 12:14 PM   #7
nicks05z71
nicks05z71's Avatar
More pics...
480 mounted - 380 on the other side
Power steering on and working great. Best 50 buck I spent on the truck I think. Going to make it so much nicer to drive.
Finaly a side shot. These are the wheels that where on it when I got the truck. sanded, cleaned, and painted white. some tires I had around the house, 255/60/15 if I remeber right.
Started running the power wire for the viairs. 4gauge on the pass. side of the truck split into 10gauge.
Old 06-24-2009, 11:11 AM   #8
mycool72
mycool72's Avatar
Keep it up! How much did you pay the spring shop to make your u-bolts?
Old 06-24-2009, 05:53 PM   #9
71'tahoe
71'tahoe's Avatar
Hella good start!!
71'tahoe is offline   Reply With Quote
Old 06-25-2009, 12:01 AM   #10
nicks05z71
nicks05z71's Avatar
They had the ubolt already made. 12bucks each, if I remeber right.
Old 06-24-2009, 07:24 PM   #11
nuke1
nuke1's Avatar
looks really nice, wish i could find a clean truck like that up here to build a shop truck, but all of ours are rusted right out.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 06-25-2009, 08:48 AM   #12
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice progress.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-25-2009, 02:20 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This is going to be a sick little shop truck, keep at it!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-02-2009, 01:40 PM   #14
nicks05z71
nicks05z71's Avatar
Been awile since I updated this. I've been working on the truck little bits at a time. To date I've mounted all 4 bags, wired, and plumbed. I havent been doing very good taking pictures sorry.. i do have a cellphone pic.
My father signed me up for a goodguys show coming up and I didnt have the truck together.. so I have not put spindles and disks on yet. Stock spindles and uncut cups. It shows because the front is still high. Ive been talking to a paint guy about some pinstripes and maybe a logo, but dont know if that will get done by the show.
Old 08-13-2009, 09:07 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
Looking good...I really like the truck! you need to post up the new pictures with the shop logos!!!
Old 08-14-2009, 07:29 AM   #16
nicks05z71
nicks05z71's Avatar
Thanks! You looking for these?
Old 08-14-2009, 08:07 AM   #17
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Dude, that turned out sweet!
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 08-14-2009, 10:30 AM   #18
71'tahoe
71'tahoe's Avatar
Thats awsome! Im digging the old faded logo's!!
Old 08-14-2009, 12:11 PM   #19
dragalac
dragalac's Avatar
Love the look thats what my truck is built to look like about to take rims off mine and put whites
dragalac is offline   Reply With Quote
Old 08-14-2009, 03:38 PM   #20
mcbassin
Still Learning
mcbassin's Avatar
nice!! VERY Nice!!
Old 08-16-2009, 06:32 PM   #21
kev2809
low n' slo
kev2809's Avatar
nice work so far, i like the look your going for. i sent you a pm also
kev2809 is offline   Reply With Quote
