04-10-2009, 07:53 PM | #1 |
3.07 gears 3 speed with a 292?
Instead of looking for an OD or finding the right T5 for my 67 C10 I thought of changing the rear to a 3.07. I have both a 3.73 and 3.07 5 lug. In the process of changing out front end.
I plan on using this as a truck but if its a real heavy load I'll just get my 3/4 ton. Might hall the occasional one axle trailer, bed full of parts, tree limbs etc. I'd like to be able to run 65 to 70 mph empty on the hwy. I have a freshened up 292, 3on the tree. Previously I had a low mileage 67 with a 250, 3speed and 3.73 with the 30X9.50's it wasnt bad with the little taller tire.. Anyone run this combo 6cyl and 3.07?
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing. |
04-10-2009, 08:24 PM | #2 |
Re: 3.07 gears 3 speed with a 292?
292 should have plenty of torque to pull the 3.07 gears. I'd do it !
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-10-2009, 09:06 PM | #3 |
i,d hunt a sm465, 4 speed trany personally that way you still have a low enough 1st gear to pull a load on takeoff . where it will kill you is backing up and pulling out and if your on a incline it will kill your clutch. been a 3 on the tree man all my life and been there done that.
I BELIEVE IN JOHN 3:16 |
04-10-2009, 10:02 PM | #4 |
its all about the +6 inches
the 4 speeds came with a 3.07, so i don't see where this would be any different as far as clutch wear. Do it. If a 292 can't handle an empty truck witha freeway gear, then it needs pitched.
04-11-2009, 04:47 PM | #5 |
Sounds like a good plan.I just don`t like 3spds.As said,1st/reverse is so high you get chatter on hills and with loads when starting off.You can find a granny 4spd and slap it in easy and cheap at some point.
04-11-2009, 05:48 PM | #6 |
4 speed tranys have a much lower first & reverse and i,ve never seen one come factory with a 3.08 gear
04-25-2009, 11:43 AM | #7 |
Out of the carpool lane.
I realize this may be apple & oranges, but fwiw I put 3.07 behind a 250 in my old '67 and while it did great at cruising speeds and above, I had to use alot of clutch at stop signs to get it up and going.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
04-25-2009, 12:21 PM | #8 |
Six in a row makes it go...
We put 3.07 gears in my buddy's '67 C10 with a 250 and 3/tree. Drove it to Alaska. No problem. Heavy load might be tough on the clutch though.
04-25-2009, 01:06 PM | #9 |
I have a 68 GMC custom 1500, it was original with a 250 3 on tree.
GMC's have no spid so I can't tell what rearend I have, It now has a 292 30 over in it, you have to slip it pretty good to get it going but boy does it have torque. Any suggestions on how to determine what gear I have |
04-25-2009, 03:05 PM | #10 | |
If you pop the rear cover, look for the numbers on the outer diameter of the ring gear. Should say 40 13 or 41-11. Divide the big one by the little one. 40/13=3.07, 41/11=3.73, etc. |
04-25-2009, 05:00 PM | #11 | |
Active Member
04-25-2009, 01:58 PM | #12 |
pop the cover off and count the teeth. The oil os probably 20+ years old anyways and no longer doing the job it was designed to do.
And not all GMC trucks were SPID-less. |
04-25-2009, 08:51 PM | #13 |
Watch out for your cornhole !
In my 72, I used to run a tired 292, 3 speed and 3.08 gears. No complaint ever. Even my tired 292 never dissapointed me.
04-25-2009, 09:24 PM | #14 |
"the other guy"
sorry to hijack.....but, i have a 67 shorty with rebuilt 250,hei,powerglide and 3.07 rear. im not planning on hauling loads,just cruisin. will this thing get out of its own way? i drove it on the property, never fast enough to get in to high. again sorry for the hijack.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
04-26-2009, 08:55 AM | #15 | |
04-26-2009, 10:07 AM | #16 | |
The nice thing was you got a lower 1st gear with the same top gear. Made it a different vehicle. |
04-26-2009, 10:13 AM | #17 |
"the other guy"
i may do that. as for not getting first, the column is from a th350 truck. now i geuss i need to look for a radiator with a cooler. my glide is air cooled
04-26-2009, 10:19 AM | #18 |
