Old 04-13-2009, 10:28 AM   #1
Sparkplug79
Rear end question
What gear ratio would be in a 79 chevy custom deluxe? it has a 250 6 banger, turbo 350 trans and a 12bolt rearend.
I tried searching but i couldnt find anything about it.
Sparkplug79 is offline   Reply With Quote
Old 04-13-2009, 11:06 AM   #2
silvereagle07
silvereagle07's Avatar
Re: Rear end question
You can take the cover off, count the teeth on the ring gear and divide it by the number of teeth on the pinion. Ring gear/pinion= gear ratio. You can also raise the truck, put in neutral, mark pinion flange, mark tire, rotate tire and count number of revolutions of pinion flange. That will get you close.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 04-13-2009, 02:32 PM   #3
Dooley
Dooley's Avatar
The 79 C10's without options and 6cyl were usually listed as having as 3.07 rear. That said, there was also available,
2.56
2.76
3.40
3.73
The "Big 10" came with the 3.40 except CA where the 3.07 was standard.
Dooley is offline   Reply With Quote
Old 04-13-2009, 05:46 PM   #4
billnorman
THANK YOU DOOLEY!!! I put a Big 10 rear end in my '85 C10. I counted the gears twice and came out to 10/34 twice (3:40). Everybody says there is only 3:43's. but NOW i'm absolved. Yes, Virginia there is a 3:40!!!!
billnorman is offline   Reply With Quote
Old 04-13-2009, 10:16 PM   #5
Dooley
Dooley's Avatar
The 3.40 axle ratio listed for some GM vehicles 1976-81 and carried a HE4 code.
Old 04-14-2009, 08:18 AM   #6
Sparkplug79
Hmm that's interesting. Was a 12 bolt standard for 79?
The only options my truck has are power steering, power brakes and that's it haha
