![]() Join Date: Mar 2003
need lite bulb sizes
need lite bulb size/numbers on the following:
dash bulb: under dash bulbs: heater control: Thanks. |
![]() Join Date: Dec 2013
Re: need lite bulb sizes
Me too!
CHEVROLET All Light Trucks*
High & low beam headlamp H6024* H6024ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen H6024XV XtraVision Halogen - The Brighter Light H6024CB Cool Blue Halogen - The Whiter Light Parking light 1157* 1157LL Long Life Upgrade: Up to twice the life of the standard lamp Front turn signal 1157* 1157LL Long Life Upgrade: Up to twice the life of the standard lamp Rear turn signal 1157* 1157LL Long Life Upgrade: Up to twice the life of the standard lamp Tail light 1157* 1157LL Long Life Upgrade: Up to twice the life of the standard lamp Stop light 1157* 1157LL Long Life Upgrade: Up to twice the life of the standard lamp License plate Assembly* Back up light 1295* 1295* 199* Front sidemarker 194* 194LL Long Life Upgrade: Up to twice the life of the standard lamp Rear sidemarker 97* Step/Courtesy light 211-2* 211-2LL Long Life Upgrade: Up to twice the life of the standard lamp Instrument-general 1445* 168* 168LL Long Life Upgrade: Up to twice the life of the standard lamp 194* 194LL Long Life Upgrade: Up to twice the life of the standard lamp Hi-beam indicator 194* 194LL Long Life Upgrade: Up to twice the life of the standard lamp Another member posted this. I saved it, Hope it helps. |
Yup, 194, also called a peanut bulb.
you can get these in LED also |
yep, just ordered 10 of those off Amazon.
What about the heater control bulb? Mine is pretty dim even with 2 bulbs. |
No, its not, The 168 and 194s push in with a tapered bottom that has 2 tiny wires that engage the socket.
The Heater control bulbs are conventional bulbs with a brass base. |
Heater control bulbs are 1894 I believe.
I change to led, still not real brite. |
I stand corrected !! My memory is not as good as it used to be.
