04-13-2009, 09:07 PM | #1 |
"the other guy"
250 ported or unported vacuum, timing
im about to start tuning my 250, i need to know if the vac advance for the hei needs to be ported or manifold vacuum? also need to know the same for the vac modulator. i rebuilt the carb and i still get the same stumble even the occasional pop when i snap the throttle. my timing tab is there but the digits are unreadable, does anyone have a readable pic of there timing tab? thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
04-14-2009, 12:27 AM | #2 |
"the other guy"
Re: 250 ported or unported vacuum, timing
any1?
04-14-2009, 06:39 AM | #3 |
What Carb?
04-14-2009, 09:38 AM | #4 |
"the other guy"
Rochester 1 barrel model b
04-14-2009, 09:57 AM | #5 |
Active Member
I've used both.
I used ported with my points distributor and I'm using non ported with my HEI (I tried it with both). I would just play with it and see which one you like. Adjust the carb for best vacuum at idle and advance the distributor (counter clockwise) so that it accelerates smoothly without hesitation. Make sure it doesn't ping/rattle under load. Mostly it's just trial and error to see what the best settings are for your vehicle. |
04-14-2009, 11:48 AM | #6 |
Its a Truck Thing......
Vac advance should use ported vac.
Modulator should be unported. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
04-14-2009, 12:02 PM | #7 |
Here's a rough sketch of the 250 timing tab .
The factory points were set @ 4degrees BTDC . With my HEI I'm set @ 10 degrees BTDC.
Working on my first 1,000 post. I'm sure I'll get there before this project is over . |
04-14-2009, 03:44 PM | #8 |
"the other guy"
blue71, it may be my computer screen but i cant make out the numbers?
04-14-2009, 04:21 PM | #9 |
12 - 8 - 4 - 0 - 4 - 8
04-14-2009, 04:26 PM | #10 |
"the other guy"
04-14-2009, 04:27 PM | #11 |
"the other guy"
12-8-4-0-4-8
\/ \/\/ \/ \/\/ is it like this?
04-14-2009, 09:06 PM | #12 |
Active Member
Here's my 250 timing mark... Graduated in 2 degree increment. If you look real close you can see where the "0" is on the third mark from the bottom. Barely see the "A" on top but it's the 8th increment from the bottom.
Ported vs. non ported has been discussed and argued but it really is up to where the truck runs the best. The following site has some real good info re: vacuum advance theory. http://www.hotrodders.com/forum/dist...1-a-59033.html |
