04-15-2009, 03:21 AM | #1 |
Sb 400 club
oil pressure on the 77 has been acting funny
So here is the scoop. when I start the truck the oil PSI is right around 40 or half way on the gauge. after driving for 30 min it dropps to just above 0. It still rises when accelerating but goes back down at idle. Is this something I should be worried about. I am not sure how much I trust the factory gauge. the engine is not burning or leaking any oil. I have a mechanical gauge on my other 350 in my 56 willys and it stays around 40 PSI all the time.
the idle is turned down on the motor and I can't rember if it dropped so much before I lowered the idle. My friend says his GMC Idles at 5 PSI when running for a while. As I said it does rise when acellerating to around 25 or so PSI. Could the sender be shot?? Or does it sound like my oil pump pickup or pump itself is going. The motor is bone stock with about 28,000 miles and has been changed regularly so I do not suspect too much sludge build up but I have never dropped the pan eather. My 84 idles at 60PSI and rises off the gauge under acceleration but it is a built motor with a high volume pump and what not.... Any input would be great. Thanks every one!
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 04-15-2009 at 03:22 AM. |
04-15-2009, 07:41 AM | #2 |
One shot, one kill.
Re: oil pressure on the 77 has been acting funny
84, Put a mechanical gage in and check the pressure. Factory gages aren't real accurite. I would think that if your pressure was 0 psi it would knock enough to get your attention, ya think? jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
04-15-2009, 08:24 AM | #3 |
The rule is usually 10 psi for every 1000 RPM.
The gasket in your oil pump may be gone/deteriorated etc and you may be experiencing loss of pressure at the pump itself. This may be why it has good pressure at start-up, your oil is colder and thicker. Or while your driving the crud in your pan is moving around and the pick-up is sucking it up against the screen, then when you park it, it releases back into the pan and creates a never ending cycle. But wth your low mileage I would'nt think so. Unless it's an original 28K truck and your valve seals have made their way to the bottom of your pan after all these years. Try a mechanical gauge and see what it does. Then act on that.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
04-15-2009, 08:17 PM | #4 |
04-16-2009, 03:20 AM | #5 |
I would be concerned. I would put a different mechanical gage on it. If it still drops off that much at idle hot, I would suspect a piece of foreign material in the oil pressure relief valve. A 28,000 mile motor should idle at 20+p.s.i. when hot. The pressure relief valve should break at 30-40- p.s.i. hot at cruise r.p.m.
I'd suspect some problem with the pump unless perhaps the wrong filter is installed or the oil is diluted with gasoline. A clogged pick-up screen usually shows up cold. Save your main bearings, keep good oil pressure. |
04-16-2009, 08:18 AM | #6 |
Yes really. That is the safe amount to have, of course others will have more than that ratio at any given RPM but that is what's considered safe.
04-15-2009, 08:44 AM | #7 |
Slots go on anything!
If it is a 77, it should have a mechanical gauge. My Blazer acted the same way with the original 400. It would also selectively burn oil. Some days, it would burn a quart of oil in 50 miles. Others it would not seem to use any. I carried a case of cheap 20W50 in the back. Anyhow, when I pulled the engine apart, there was a ton of stuff in the pan. It looked like someone had resealed the pan with 2 or 3 tubes of silicone, and most of that was in the pan, along with most of the valve seals and a bunch of nylon timing gear teeth. I did a cheap rebuild (college budget, so it was rings, bearings, and gaskets only) and the engine never used oil after that. The oil pressure fluctuated a lot, too. I am betting on the oil pump pickup being full of debris. If that is the case, ther emay be some in the tube that goes to your oil pressure gauge, too.
04-15-2009, 08:15 PM | #8 |
Start with the mechanical gauge first but I will agree with Jonboy, had a similar problem with mine this past winter, after I did a oil change. A quick peek an your bottom end with the pan off, won't hurt anything, an you'll definately get to see if you have anything if at all in your oil pan!!!
Once a Marine Always a Marine OOH-RAH GM Fanatic 1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!" 1986 c30 camper special 454, th400 (for sale) 1984 K10 Big Ten (project) needs motor 1984 C10 355, 700r4, (project) needs shortbox bed |
04-16-2009, 08:14 AM | #9 |
Sb 400 club
It has been running rich. I would say idle rpm is definatly lower then 1,000 right now. Dang I am goning to have to look into this further soon.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
