Old 04-17-2009, 02:00 PM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
under the hood help
Since I removed about every thing in the engine bay, the a/c box since it was missing about every thing to make it work, hid the wiring since the wiring was a mess most of the wires were fried and I was afraid that my truck would catch on fire so I rewired with a new harness, and put the battery in the bed now I need help of making it look better,
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-17-2009, 02:09 PM   #2
flamingbig10
6.0 powered square
Re: under the hood help
Aaron
Old 04-17-2009, 02:24 PM   #3
flamingbig10
6.0 powered square
For the firewall I'm going to use a piece of sheet metal that my dad cut out for me, but it will need a lot trimming and fitting, and also I'm going to wrap the headers and use a small brake booster, also I need to put something under the hood because when the hood is open it make the truck look bad
Aaron
Old 04-17-2009, 03:06 PM   #4
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
You could look at covering, or filling the holes in the fenders. That would clean it up. And, maybe loose the Summit sticker. That is my $0.02.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 04-17-2009, 03:22 PM   #5
flamingbig10
6.0 powered square
the air cleaner is going away once I find a one that like since this one is thrashed,
Aaron
Old 04-17-2009, 07:30 PM   #6
Driveway Dreams
I have car A.D.D.
Oh, cool. Your truck might look sweet with an old Caddy/Olds air cleaner. Painted to match the truck.
-Gerald
Old 04-17-2009, 08:35 PM   #7
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
My $.02:
I'd either paint the wells to match the inner fenders or the other way around to clean up the look. If the inner fenders were black, the cutouts wouldn't stand out as much.
Get an insulator for the hood. They clean up nicely.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 04-17-2009, 10:54 PM   #8
flamingbig10
6.0 powered square
air cleaner http://www.speedwaymotors.com/Retro-...aner,1052.html
like this
or the gutter below the hood painted black
Aaron
Old 04-17-2009, 11:07 PM   #9
bigblock73
yeller
bigblock73's Avatar
Here are some of the things I did to my 73 to clean up the engine bay.
bigblock73 is offline   Reply With Quote
Old 04-20-2009, 12:25 AM   #10
RonnieTheBull
Great idea with the harness cover....been looking for something like this....honestly dont feel I have the craftsmanship to fab one myself...good stuff
RonnieTheBull is offline   Reply With Quote
Old 04-17-2009, 11:12 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Things that would make a big difference-
1. Remove the hood and paint the bottom side of it white. Be careful to protect the top from scratches and overspray.
2.Paint the firewall white.
3. Make one piece cover panels to fit the inner fenders and paint them white as well.
4. Paint fender liners white.
5 repaint the booster/master cylinder satin black. Add a chrome lid.
6 Loose the T-handle hold downs.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-17-2009, 11:37 PM   #12
flamingbig10
6.0 powered square
I was Going to have all of the under area painted white but since it's a daily driver and the black shows less dirt, but I will do #5 and #6
Aaron
Old 04-17-2009, 11:14 PM   #13
bigblock73
yeller
bigblock73's Avatar
All the wiring is hidden, including the headlight harness being routed inside the fenders and along the bottom of the core support. Firewall shaved, insides of fenders and hood undercoated, fuse box cover (yet to be finished), ignition components inside the cab, low mount brackets from Alan Grove, and matched components wherever I could.
I suggest you ditch the cheesy braided hose wrap and colored fittings and run new black hoses with SS clamps, match the VC's and air cleaner, de-sticker everything, undercoat the inside of the fenders and hood, new insulaton, clean up the engine (at least the intake), black plug wires, etc. Take a step back, if anything really grabs your eye...lose it or detail it.
Old 04-17-2009, 11:50 PM   #14
flamingbig10
6.0 powered square
I have hid all of the wire except for the wiper motor, the intakes dirty because of cheap made water neck leaking coolant
Aaron
Old 04-19-2009, 11:33 PM   #15
flamingbig10
6.0 powered square
I thought a little more, Paint the fenders below the gutter black, welds up the holes on the inner fenders , add the sheet metal on the firewall, weld up the holes on the core support, and paint black, a replacement hood liner, make a peace of sheet metal covering the top of the radiator, and go from there
Aaron
Old 04-20-2009, 01:50 AM   #16
flamingbig10
6.0 powered square
so fare I sanded the fenders, fixed the leaky water neck, and removed the summit sticker
Aaron
Old 04-20-2009, 02:45 AM   #17
enaberif
now you need a nice big 4-5" air cleaner on that baby!
enaberif is offline   Reply With Quote
Old 04-20-2009, 11:26 PM   #18
flamingbig10
6.0 powered square
I worked on the sheet metal today
Aaron
Old 04-21-2009, 12:18 AM   #19
flamingbig10
6.0 powered square
A few Items I thought of
for now
http://www.classicparts.com/1973-98-...ctinfo/38-375/
later on
http://store.summitracing.com/partde...5&autoview=sku
Aaron
Old 04-21-2009, 12:47 AM   #20
bumslie75
bumslie75's Avatar
Looking good I got a 87 im starting to tear apart what are you doing on the inside
bumslie75 is offline   Reply With Quote
Old 04-21-2009, 01:12 AM   #21
flamingbig10
6.0 powered square
thanks, interior is a work in progress http://67-72chevytrucks.com/vboard/s...d.php?t=333939
Aaron
Old 04-21-2009, 10:56 PM   #22
flamingbig10
6.0 powered square
I painted a part of the fender since, I didn't want to tape the entire front half of the truck
Aaron
Old 04-21-2009, 11:31 PM   #23
flamingbig10
6.0 powered square
once I fill in the holes and do a little body work then me or my dad is going to spray some valspar Tractor & Implement Enamel, like was sprayed 3 years ago
Aaron
Old 04-22-2009, 01:13 PM   #24
flamingbig10
6.0 powered square
Aaron
