Old 04-20-2009, 09:08 PM   #1
karlbenz
64 body swap
thinkin bout mounting my 64 cab (only) on my 86 4x4 frame and drivetrain. testing the waters here, lookin for input on possible obstacles i might run it to. any input would be appreciated.
karl
karlbenz is offline   Reply With Quote
Old 04-20-2009, 11:11 PM   #2
Captainfab
60-66 Nut
Re: 64 body swap
The '73-'87 frames drops down lower under the cab area than the '72 and older frames. When doing a complete body swap such as this you would end up with a body lift unless you channel the front clip and the box over the frame.
You say you are using the cab only.....are you building a truggy?
Old 04-21-2009, 06:33 AM   #3
karlbenz
Re: 64 body swap
puttin a flatbed on it to haul my 4 wheeler and hog dogs. how much body lift you think i would end up with? i am a fabricator by trade so shouldn't be any trouble.
thanks
karl
Old 04-29-2009, 03:12 PM   #4
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: 64 body swap
I did a 66 onto a 77.
Look at my sig....
Joey~AP is offline   Reply With Quote
Old 05-02-2009, 08:46 PM   #5
karlbenz
Re: 64 body swap
will i need a high hump floor? if so where would i get one or would i have to build one? how much body lift will i end up with?
Old 05-03-2009, 12:26 AM   #6
Captainfab
60-66 Nut
Re: 64 body swap
You'll end up with about a 3" body lift. I wouldn't think you would need a high hump trans cover since you'll be lifting the body. If you do need one I can fix you up.
The other option to doing the body lift would be to channel the front clip and the bed down over the frame. Probably 6 of one half dozen of the other depending on your preference.
Old 05-03-2009, 01:49 AM   #7
oklahomaduner
oklahomaduner's Avatar
Re: 64 body swap
I am about to do the same thing. but the bed too.
oklahomaduner is offline   Reply With Quote
Old 05-04-2009, 12:00 AM   #8
Captainfab
60-66 Nut
Re: 64 body swap
On the truck you are building, to put that body on that frame you will have to either build new cab and box mounts which will give you a body lift, or channel the front clip and the box down over the frame. IIRC the box won't need as much as the front clip.
Old 05-04-2009, 09:59 PM   #9
karlbenz
Re: 64 body swap
anyone got any pics of channeling the front clip to give me an idea of what i am getting into? i would rather not do the body lift
Old 05-05-2009, 12:55 AM   #10
Captainfab
60-66 Nut
Re: 64 body swap
I don't have any pics, but basically you'll have to cut the frame just behind the radiator support and drop it down to lne up the front clip with the height of the cab. Of course while doing this you could also replace the '86 frame horn with the '64 frame horns so you can run the '64 front bumper.
This will be about the same as the lowriders guys do when they 'Z' the frame. There's sure to be some pics of that here somewhere.
Old 05-06-2009, 05:07 PM   #11
karlbenz
Re: 64 body swap
i can't cut the frame behind the rad. support because of the front spring shackle??
Old 05-03-2009, 09:22 AM   #12
Mudder
Mudder's Avatar
Re: 64 body swap
The newer frames raise sharply after or right behind the cab. That is were most of the problem will be I think. Even if I had a high hump on my 67 I wouldn't be able to lower it anymore without doing extensive cutting on the rear of the cab.
I think if a guy could get ahold of a Burb frame that would work better.
Mudder is offline   Reply With Quote
Old 05-05-2009, 09:53 PM   #13
oklahomaduner
Re: 64 body swap
are there any close up pics of what the body lift looks like to do this?
