04-21-2009, 01:40 PM | #1 |
12 volt supply
Trying to connect my holley 600 choke wire to a 12volt source other than my ignition wire. Don't want to steal voltage from my distributor.. Anyone know of another wire that supplies 12 volts only when the ignition is on?
04-21-2009, 02:41 PM | #2 |
Gone to greener pastures
Re: 12 volt supply
Unless you have an HEI, your ignition wire is only about 9 V.
Putting that aside, you should be able to pull a switched 12 V source off your fuse block, someplace. I'm not trying to be a hard a**, or a butthead, but you can pull off of other circuits there. I hope that helps you at least a little bit. LJ P.S. Welcome to the board!!!!!!!!!!!!!!!!
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 04-21-2009 at 02:42 PM. |
04-21-2009, 02:54 PM | #3 |
Re: 12 volt supply
kinda on the same line, i converted to hei, and an electric fuel pump. i have 1 12 gauge wire routed from the ignition, to the right side of the engine where it splits into 3 leads, 1 to hei 1 to choke, and one to pump. that be ok to run that much amperage through that one line? Or should i install some relays and wire directly from the batt?
04-21-2009, 03:01 PM | #4 | |
Between Trucks...
Re: 12 volt supply
Beat it to fit, Paint it to match... |
04-21-2009, 03:05 PM | #5 |
Re: 12 volt supply
get a voltmeter and check the open spades in your fusebox for 12 volt sources that come on when your headlights do
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
04-21-2009, 03:10 PM | #6 |
Between Trucks...
Re: 12 volt supply
You actually want a key on source. You can put on your head lights with the key off.
04-21-2009, 06:34 PM | #7 |
Re: 12 volt supply
whoops, sorry I meant to say Ignition.
04-21-2009, 04:55 PM | #8 |
Re: 12 volt supply
69time,
I'm sure the HEI will like the 12v. You could get a meter at Wal-mart for around $10. There not the fanciest, but they work and you can keep it in your truck.
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 04-21-2009 at 04:56 PM. |
04-21-2009, 05:08 PM | #9 | |
Re: 12 volt supply
Do you really need a choke down there in TX? Up here where I live, It sometimes gets down into the freezing range, but not real often. The choke on my Chevy is blocked open. When it's really cold, I just pump the throttle twice & then hold it about 1/2 way down. When I hit the starter, it generally fires right off. Sometimes, I admit, I have to crank it a bit; but not real often.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-21-2009, 03:14 PM | #10 |
Re: 12 volt supply
there should be more than one ignition lead coming off the ignition switch you could run it off that.
04-21-2009, 03:20 PM | #11 |
Re: 12 volt supply
There is a switched connector in the fuse box, run off of that, you don't need the full 12V for a choke, just enough to heat up the element.
04-21-2009, 03:51 PM | #12 |
Re: 12 volt supply
Well, I'm kinda just shooting in the dark here. When I initially installed the Holley 600 I connected the choke wire to the ignition, cranked it and it idled up as it should have then settled back down once warmed up. Did this for two days and now it seems that the choke is not responding at all anymore. So I read the carb manual and read where it stated not to use the ignition wire as the source but to find an alternative 12v ignition activated source and here I am.. I don't have a meter to meassure the open spade in the fuse box and I have upped to the HEI..
