04-21-2009, 04:29 PM | #1 |
Suspension / Driveline set-up questions
Gentlemen,
Need some help understanding my next steps in the suspension and driveline department. Ive added a set of 6" TC lift springs to my Jimmy (also 3" body lift), and used a 14bff rear and D60 front. (New perches on the 14bff were installed at the same angle as the stock ones, but moved in to match the new width) Of course now, the stock slip-drivelines from the 205 wont mount up to the new axles unless there is changes in length and/or universal joint size. This is where I get confused on my best options.... Do I need a transfer case drop kit? Do I need to have my drivelines lengthened? If I do, where are the measurments taken? Do I need to use a shim w/certain degree to correct angle to the axles? Do i get a conversion u-joint or better to upgrade the driveline itself to a larger 1 ton matching yoke size? Someone please steer me in the right direction, it would be greatly appreciated. I want to do this right and have it drive like its 'sposed too when its done. -RMK
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler |
04-21-2009, 05:14 PM | #2 |
Re: Suspension / Driveline set-up questions
My .02c
I would have waited to weld the perches to the axle untill after you get a driveline installed. Just install the rear without welding the perches so you can adjust pinion angle as needed, no shims needed. If you do use shims make sure you buy STEEL, the alum ones will crack in time and spit out leaving your Ubolts hella loose (this happend to me and luckly I cought it and only suffered bent spring perches) I would get new drivelines ~ HighAngle or TomWoods or local driveline shop that can build some beef for you with the correct yokes/u-joints. To measure your driveline = Xfercase yoke to pumkin yoke (the half circle area were the Ujoint seats into) that in your installed length. The driveline must be able to move inward and outward when flexing. I have never been a fan of droping the tranny/xfer case mounts, at only 6in of lift you should not have to do that, I wouldn't. I use CV-joints on both my front and rear drivelines. With CV type you point the diff pumpkin straight to the xfer case. With non-CV driveline you have to make sure Xfercase yoke angle and pumkin yoke angle are the same so they cancel eachother out when spinning (within 3deg I think). You can also run a flange at your xfer case the eliminates the u-joint type yoke, 4bolts instead... This is a 1350CV type with flange mounting at the Xfer .120 wall tube. & 1410 Ujoint at the rear diff. from High Angle Drivline. Hope this helps! Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
04-22-2009, 10:36 AM | #3 |
Burt4x4, thanks really appreciate your help.
Im going to see what my angles are, and get my drivelines modd'ed up at a local driveline shop. I know you want the yokes to be parallel (xfer and diff) so it seemed like if you put the perches at the same angle as stock, they would surely be parallel as from the factory, just at a steeper angle.
04-22-2009, 11:26 AM | #4 |
"I know you want the yokes to be parallel (xfer and diff) so it seemed like if you put the perches at the same angle as stock, they would surely be parallel as from the factory, just at a steeper angle."
Yes, true for non CV type drivelines. Going with a CV type alows you to rotate the pinion angle up for added ground clearance One half dozen or another, 12 ways to skin a cat hehehe Good Luck
04-22-2009, 11:51 AM | #5 |
So with a constant velocity joint dont they need to be pretty much pointed directly at each other? How did you angle the xfer case towards the pumpkin?
It sounds from your post above maybe you just need a straight shot from the pumpkin only if you go that route?....
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler Last edited by RckyMntnKng; 04-22-2009 at 11:52 AM. |
04-22-2009, 01:17 PM | #6 |
Ya the CV is at the xfer case so no need to change that angle at all. Then you just pioint the pinnion yoke/pumkin straight at the xfer. THe CV joint does all the majic to keep it vibration free
04-22-2009, 02:50 PM | #7 |
Sounds great, maybe I should go that route myself. Thanks again man, you and VT always have the answers.
04-22-2009, 03:30 PM | #8 |
I'm watching, going to go this route myself. D60 in frt, and 14bt., in rear. Cool!
04-22-2009, 03:59 PM | #9 |
How the hell do you measure the angle of your yokes to the accuracy of 2deg or less?
04-22-2009, 04:05 PM | #10 |
Magnetic Angle Finder
04-22-2009, 04:32 PM | #11 |
Wow...how much to rent that to me for a day?
04-23-2009, 09:18 AM | #12 |
Good Morning
Do you have a harborfrieght or notherntool near you? They are just a few bucks at thoes discount tool stores Google it I have a black one, that pic was pulled from google
04-23-2009, 10:30 AM | #13 |
Found one last night at home depot!
Gonna pull my drivelines this weekend and grab some measurments, drop them off at a shop and see what they can do me for
04-23-2009, 06:43 PM | #14 |
Question about the rotation of the pinion for a CV joint - how man degrees can you rotate a 14bolt rear end and still get adequate oiling?
How do you use the the angle finder to set the pinion rotation? So you get the angle finder on the pinion with your perches loose and you start rotating it up...but what is going to tell you to stop rotating the pinion up? |
04-23-2009, 07:12 PM | #15 |
I can answer the angle question.....Whatever angle your Xfer case is at is what you try to match on your diff angle. The goal is to get them parallel as possible, so the rotational speed at both ends is the same....ie no harsh vibrations.
