04-22-2009, 12:00 PM | #1 |
Between Trucks...
Change cam with motor in truck?
Is it possible to change the cam with the motor in the truck? Do you have to pull the grill?
Beat it to fit, Paint it to match... |
04-22-2009, 12:28 PM | #2 |
Location: Sunny, Florida, some might call it South Alabama
Re: Change cam with motor in truck?
I have been told that you can do it. And that you just pull the radiator and all the accesories on the front of the motor. But I am not sure if I believe that or not...LOL
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
04-22-2009, 12:59 PM | #3 |
you have to remove the Headers or manifolds which ever you have, the intake the heads the radiator and all the accessories, the water pump, basically everything, use a magnet to get out the lifters. I recommend just yanking the motor.
71 Chevy Custom Deluxe 10 All original, although in need of some TLC. only 3 owners, my grandpa, my dad, and me. |
04-22-2009, 01:07 PM | #4 |
Why do you remove heads and headers? I can't recall doing this when I swapped a cam in my 84 Camaro some ago...
04-22-2009, 02:28 PM | #5 |
no you dont have to remove headers and heads to change the cam in or out of the truck. as far as the grill may be a tape measure would be the best way to check. the cam is just about as long as the block, if you have enough to stick another engine in front of your present one then you can leave the grill.
04-22-2009, 02:59 PM | #6 |
IT can be done. Its not fun but it can be done.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
04-22-2009, 04:28 PM | #7 |
It'll Buff Out!
I just did mine this weekend with the motor in the truck. I will try and give you an idea of how it went.
I pumped down the A/C Disconnect the battery Drained the coolant Aired down the front tires (I have 33’s so this makes it easier to work on this project) Removed the egg crate (I left my grill in) Removed the radiator Removed the condenser Removed the center support Removed the belts Removed the Fan clutch Removed the water pump Removed the Dampener pulley Removed the timing chain cover Check for TDC (I pulled my plugs since I was going to change them) Removed the dizzy Removed the Carb Removed the intake Removed the valve covers Loosened the lifters and removed the pushrods. ( I like to keep left bank separate from right and I also checked to make sure I had no bent ones.) Removed lifters with magnet Unbolt fuel pump and let the rod drop out of the cam’s way Removed the timing chain Removed the Cam (Screw in a few bolts that fit so you can get a grip on it gently wiggle and pull like you were delivering your first born son. If it’s stubborn give him a few togs. but, be careful of the bearings. You don’t want to have to beat it out with a hammer or you will have/already have other serious problems.) You can inspect your cam bearings at this time (what you can see of them) if you see any broken or cracked I would stop until you can pull the motor. Cover lifter valley with rags remove large chunks of gasket by hand, scrape off remaining. REMOVE RAGS Clean up the timing chain area. I trimmed my oil pan gasket back to flush. Inspect new cam then lube, lube again and lube some more. Slowly walk it, wiggle it and walk it back into place. Lube up your lifters with cam lube. And reinstall timing gear. From here it just putting everything back on, new seals, gaskets, etc. This is a write up of how what I did with the engine in the truck. I am sure every one does it their own way. I started this project because I had a lifter ticking and my dampener pulley slipped so I couldn't set proper timing. I know the rest of the motor is in good shape from an earlier tear down. What I was asked from when I was calling vendors about my cam. (This may help or you may already know this.) I told them I wanted to use stock push rods and valve springs. They wanted to know if my valve springs were still good I knew they were from an earlier tear down So that set the parameters for what Cam’s I could use and since I was tearing it all apart I put a new timing gear in it, new water pump and new intake. I wish I would have taken step by step pictures but I am working on it at my buddies since he has all the pullers and odd tools I don’t have. Also don’t forget to use a break in lube and good oil (I used Valvoline VR 20-50(high zinc) and follow the cam specs for break in (mine is 2500 rpm for ½ hour) This is by no means meant to be a guide more my point of view of what I did and how it can be done in the truck. Good luck. I am finishing mine hopefully this weekend I do have before and after pics and will post them then.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB Last edited by So.Cal.Super; 04-22-2009 at 04:32 PM. Reason: grammer |
04-22-2009, 01:03 PM | #8 |
I did this when I had a lobe wear down on
a new engine. It has been a few years. As I remember, I had to pull the radiator, water pump, intake and timing chain cover. I had to pull the lifters and the new cam went in ok. Something to consider is the age of the engine and wear on the cam bearings. Cleanness is critical. Go easy to avoid damaging the bearings. EdB |
04-22-2009, 05:51 PM | #9 |
Between Trucks...
Cool, thanks guys.
04-23-2009, 06:29 AM | #10 |
Project: years too late.
my dad used to change out cams in his truck in an hour, befor he had to go home from work lol. He didnt pull the motor, so it can be done.
Just the rad, some people pull the grill just to be safe, but there should be enough room from the front of the block to the grill, to get the old cam out and the new one in. As far as i know all you realy need to take off is : Waterpump, any other front end components in the way, and move the rad.
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here. |
04-23-2009, 07:52 AM | #11 |
ASE master tech/machinist
Also don't forget one key factor. Only lube the bottom side of the lifters, DON'T lube the sides, they will not rotate in the lifter bores and flatten the lobes on your new cam.
"I sit here and I pray in my broken down Chevrolet....." |
04-23-2009, 10:19 AM | #12 |
You had to say that. I just installed my cam and lifters and put a ring of lube around the bottom of the lifter sides, AND put the intake on already.
04-23-2009, 10:48 AM | #13 |
20' Daredevil (Ret)
Isn't the lube for protection upon initial startup -- and won't it be washed off by normal oil flow in a reasonable amount of time as the engine runs, therefore allowing the lifters to rotate as normal?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-23-2009, 11:03 AM | #14 |
Everywhere I've read says lube bottom side of lifter. The vortec intake gasket is $30.00. I hate to have to buy a new one.
04-23-2009, 11:40 AM | #15 |
It'll Buff Out!
I have never heard this before but I can say that about a lot of things. I just called edelbrock tech to ask them since I have always coated my lifters during a swap out.... on hold with tech now.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
04-23-2009, 12:07 PM | #16 |
It'll Buff Out!
According to Edelbrock tech this will not cause lobe wear. Chris who I spoke with and he double checked with a few others while I was on hold for quite a few mins. They all agreed this would not cause a problem. What would cause a problem was if the bottom of the lifters were not coated at all. But coating the sides with assembly lube just insures some lubrication during start up to prevent wear.
This is how I have always done my cam change outs (probably half a dozen with friends and all) and have never had a problem. And since this is who is warranting my cam I will go with they tell me.
04-23-2009, 12:27 PM | #17 |
if you have the plasic gaskets with O-rings, they should be reusable. if not, get 'em they work great
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
04-23-2009, 11:58 AM | #18 |
Between Trucks...
In "How to Build the Smallblock Chevrolet", it says breakin lube on the cam contact surface of the lifter and assembly lube on the outside of the lifter.
Beat it to fit, Paint it to match... Last edited by Sinister; 04-23-2009 at 11:58 AM. |
