04-22-2009, 06:16 PM | #1 |
Leaking from carb fuel filter
So I changed the fuel filter the other day in my brother's 86 GMC Sierra with a 350 and a 4 barrel carb. Ever since then, it's got a pretty good leak coming from the fuel filter connection (The big connection that goes to the carb, not the small connection that goes to the big connection)
Did I lose a rubber washer or something when I took it all apart? I've verified that it's screwed on straight and that it is screwed on tight, but it's still leaking around the threads. Not sure what to do next, since I'm not sure what the problem is. Do the auto parts stores sell the metal piece that the fuel filter sits in and connects to the carb? Thanks in advance...
Blue - 77 Chevy Scottsdale |
04-22-2009, 06:38 PM | #2 |
STILL PLAYS WITH TRUX
Re: Leaking from carb fuel filter
More than likely there was some sort of a gasket under that fitting and you will need to remove it and go to any auto parts store with that fitting and get a new one also find out what mfg made the carb.
04-22-2009, 10:47 PM | #3 |
Robert Olson Transport
there is usually a nylon washer kinda thing and usually white in color that goes between the carb and the filter fitting. If this is missing it will leak and if this is screwed in crooked it will leak they used to sell them in HELP in the auto parts store
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-23-2009, 12:03 AM | #4 |
Aha...That white nylon washer is what's missing. I saw it on the ground after I changed it out, but I thought it was just one of the random pieces of crap lying around out there. I'll go try to find it.
If I can't find it, I sure hope the auto parts store has one..
04-23-2009, 10:06 AM | #5 | |
04-23-2009, 10:08 AM | #6 |
I actually just got finished fixing it. Found the washer sitting on top of the tool box. No leak anymore
Thanks for your help.
