Old 04-25-2009, 05:33 PM   #1
Wootdog
Wootdog's Avatar
Adjustable Pan Hard Bar Question
Guys,
It has been a while since I posted. Been working on the 67 C10 stepside. It has a nine inch rearend that required the housing to be replaced. When my brother originally got the rear end shortened, the left tube was out of round. Also the end of the housing on the left side was not welded on correctly. Which meant that the bolts that hold the axle in on the drivers side were out of proportion with the right side. The axle on the left side started to bind which meant it housing needed replaced. the internals are ok. With that being said, While trying to adjust the side to side action, I now see that the original pan hard bar is a inch too short. It appears the people that shortened the F150 axle housing didn't get it quite right. My dilema is that I need to find a panhard bar that is approximately 28.5 inches wide vice the 27.5 inch one I have now. I figure that with the rear end hanging loose, it is exactly two inches to the right. The pan hard bar is one inch too short. If I obtain a one inch longer pan hard bar (adjustable of course) that I should be able to adjust the axle one inch to the left. Then tighten everything down. Sorry for the rambling but I have been working on this frickin thing for going on three weekends and I am ticked off.
Thanks for listening to my rambling.
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 04-25-2009, 05:55 PM   #2
cdowns
cdowns's Avatar
Re: Adjustable Pan Hard Bar Question
move the mount on the housing is what i'd do
Old 04-25-2009, 05:58 PM   #3
Wootdog
Wootdog's Avatar
It is weled on. And I only have a wire feed welder.
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 04-25-2009, 06:03 PM   #4
jbristo67
resident oilfield trash
jbristo67's Avatar
Heres what I did deluxe trac bar from CPP 109 on ebay 10 shipping
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 04-25-2009, 06:13 PM   #5
Wootdog
Wootdog's Avatar
I saw that. The mount for mine is on the right side on top of the axle housing about half way between the differential and the right wheel. How does that mount?
Thanks,
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 04-25-2009, 06:15 PM   #6
jbristo67
jbristo67's Avatar
Passenger side u bolt on the rear end
2011 Nissan Armada
Old 04-25-2009, 06:20 PM   #7
bigguy69
dazed and confused
bigguy69's Avatar
i got mine from early classic ent. it is a deluxe trac bar and mounts the same way
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 04-26-2009, 07:36 AM   #8
Wootdog
Wootdog's Avatar
Anyone have a similar setup to mine with the Ford Nine Inch rearend? Could I get a close up of your guys install?
Thanks,
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 04-26-2009, 09:21 AM   #9
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I dont have a picture, but I have a 9". I use the adjustable track bar from Early Classic Enterprises... it comes with the mount, which bolts on to the passenger side trailing arm. Id just get that and be done with it.
Tom Vogel is offline   Reply With Quote
Old 04-26-2009, 10:34 AM   #10
fleetimus
fleetimus's Avatar
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
Old 04-26-2009, 10:37 AM   #11
ed2552
ed2552's Avatar
The panhard bar is the same 1/2 to 3/4 ton, correct?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-26-2009, 11:16 AM   #12
Wootdog
Wootdog's Avatar
Thanks for the pictures. It figures, after as hard as it was to get the rear ubolt in and the right front trailing arm, It I guess will need to come back off.
This is the 33" inch adjustable one, correct?
Thanks again,
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 04-26-2009, 11:19 AM   #13
Wootdog
Wootdog's Avatar
Does anyone know where I can just buy the ends that are adjustable? I just need one or the other that can screw into the panhard bar I have. I have 1 1/2" ends now. I need at least one 2 1/2" end.
Thanks again,
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 05-10-2009, 07:37 AM   #14
Wootdog
Wootdog's Avatar
TTT
Kerry
1967 C10
1969 Chevelle
2002 Silverado LT
Old 05-10-2009, 07:55 PM   #15
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you know the length you need, just cut and weld as needed to arrive at the desired length.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-11-2009, 09:48 AM   #16
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Also do all your measuring at ride height, The arc of the bar will change as you lift or lower the rearend.
sneakysnake is offline   Reply With Quote
Old 05-11-2009, 02:26 PM   #17
Andy4639
Old member
Andy4639's Avatar
Here is my adjustable bar. It ant so adjustable once installed though.
Driver's side.
Passenger side.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
