04-26-2009, 11:58 AM | #1 |
454 MAKES IT ROAR
Sway Bar Rivets.
A while ago I discovered that one of the two Rivets on my front sway bar was missing so I put a nut and bolt in there and forgot about it, then a while later noticed that it had worked loose so I added a lock nut with the split washer and it still worked loose. Now checking it the other day to see if it had loosened since, I found that it had and the one remaining Rivet had disappeared, sheared off I suppose....My question is this....is it essential that the sway bar brackets are Riveted on and not Bolted? If so how the heck do you install Rivets without working in a ship yard?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
04-26-2009, 01:11 PM | #2 |
Roadtrip!
Re: Sway Bar Rivets.
I don't know why you couldn't use bolts with lock washers. You could use grade 8 stuff for piece of mind...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-26-2009, 01:36 PM | #3 |
laying low
8B. Is that thumpin big block shaking the frame apart? Grade 8 with lock washers ought to stay put. Maybe include some thread locker?
04-26-2009, 01:47 PM | #4 |
all you need to rivet something is a metal rod a torch and a hammer and dolly plus a bit of imagination
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-26-2009 at 01:48 PM. |
04-26-2009, 01:52 PM | #5 | ||
454 MAKES IT ROAR
Do you guys have Bolts or Rivets?
04-26-2009, 02:00 PM | #6 |
Added sway bars to two of our trucks, just use grade 5 minimum, (3 lines) or better yet use grade 8, (6 lines). If you look at the factory bolts that hold the bushings on you will see that they are 3 line (grade5), we used grade 8 bolts, lock washers and nuts just to be sure, the plating is ususally better on the grade 8 also and won't tarnish as fast and look new longer.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-26-2009, 02:11 PM | #7 | ||
454 MAKES IT ROAR
Green when you say "lines" are you refering to the small lines that I have seen on the heads of the Bolts on my Truck?
04-26-2009, 03:06 PM | #8 |
Sisyphus was my mentor!
The parts are only as good as what holds it together. I try & use the best bolt for the job, & that doesn’t necessarily mean using a Grade 8 nut/bolt on everything as they are expensive. You don’t need Grade 8 hardware to hold your glove box door on. (Unless you're REALLY hardcore!) There's a time & a place for the high strength stuff. Your application eightbanger is Grade 8 country. In my sway bar installation, I used Grade 8 bolts with hardened washers & Grade 8 nylon locknuts. I haven’t checked them in a while, but I'm confident they are at what I torqued them to 5 years ago.
http://www.boltdepot.com/fastener-in...ade-Chart.aspx http://www.americanfastener.com/tech...ings_steel.asp http://www.rockcrawler.com/techrepor...ners/index.asp
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 04-26-2009 at 03:10 PM. Reason: Spelling... |
