04-26-2009, 11:08 PM | #1 |
Manual Tranny Question
I have a line on a sm465 Which i believe is a granny low tranny. What all is involved in changing one out? I currently have a 3 speed. The tranny is free by the way all i need is a shifter. I have a high hump floorboard section as well as If i remember correctly its gonna need.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
04-27-2009, 05:14 AM | #2 |
Re: Manual Tranny Question
I just finished doing this myself. The 4-speed will bolt right in. You will either need a 4-speed drive shaft, or have yours changed because the slip joint on the 3-speed goes into the trans, while the 4-speed shaft has the joint in the shaft.
1967 K-20, 1969 K-20, 1970 C-30 dump,1971 K-20 1972 K-20, 1972 C-10, 1968 Grandprix John Deere 350c Dozer, 3414 International backhoe 1972 International 1600 Flatbed |
04-27-2009, 08:52 AM | #3 | |
I considered doing the nv4500 swap but this one is free and it will give me the pulling gears I want. Plus I just like a floor shifter. Gives me someplace to rest my hand. LOL
04-27-2009, 06:09 PM | #4 |
The 465 has a larger front brg. retainer. You will need a different bell housing.
04-27-2009, 06:28 PM | #5 |
I just removed my SM465, and it's heavy. 185lbs heavy. So keep that in mind when removing so the clutch isn't damaged while sliding it out or you're like me and crack the driveway.
The shifter on the trans is a funny one to remove if you haven't done it. The mounting "ball" needs to be pushed in a turned counter clockwise to remove. I piece of dowel should do the trick. You'll have to remove the long shifter before the install. The output is usually a static yoke so you may need a completely different d-shaft to accomodate for the slip. The Transmission is shorter and I belive you'll need a "mid hump", but I may be incorrect. My truck did the swap from the 3 speed before I got it, and had a new hump installed. You'll rarely use 1st gear, but it does come in handy from time to time. That trans can handle a 2 ton truck, so it'll feel really "torque-y" |
04-28-2009, 09:56 AM | #6 |
This one dosent come with a shifter so Ill have to find one. Its sitting in a garage and i didnt see a bellhousing near by so ill have to check on that. I didnt really look real well either. Does anyone know if the starter will bolt to the bellhousing like mine currently does or will i need to put a block one on it? Does anyone have any pics of theirs?
04-28-2009, 11:48 AM | #7 |
good luck on it
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
04-28-2009, 12:16 PM | #8 |
67 and older used a 4 11/16 bearing retainer, 68 up used a 5 1/8 retainer size, just make sure they are both the same. Do not not put a tranny with a small retainer into a bell with a large hole, those parts work together to align everthing up and keep the trans centered.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-28-2009, 02:39 PM | #9 | |
You know one could take that completely wrong now that I think about it !!!
04-28-2009, 02:43 PM | #10 |
Truck Enthusiast
i have two of those in the scrap pile now.free if u can pick up in merced, ca
04-28-2009, 02:53 PM | #11 |
As much As i would like to come visit its a bit far from TN. Thanks though!!.
04-28-2009, 02:55 PM | #12 |
Truck Enthusiast
i also have a cpl of 203 tfr cases if anybodys interested local
