Old 04-27-2009, 10:36 AM   #1
lks dcvn
lks dcvn's Avatar
Trans Fluid - leaking down front driveshaft
Got some time to move some stuff around in the garage last weekend...
I was sweeping some leaves and spotted a few drips of what appeared to be trans fluid spots under the front driveshaft - I put a small bucket under it and in the past week it has put a layer of fluid in the bottom of the bucket.
Any idea what this is - and could it be from just sitting all winter?
I can get a pic when I get home if that helps...
lks dcvn is offline   Reply With Quote
Old 04-27-2009, 10:51 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Trans Fluid - leaking down front driveshaft
The seals in the transmission have probably dried up from sitting. I've heard it is a common problem with the older transmissions.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-27-2009, 05:25 PM   #3
cparman
sharp as a marble
most of the transmission fluid in any automatic is stored in the torque converter. If you Blazer has been sitting for a long time, the converter could have drained some of the fluid into the body of the transmission. There isn't much room in the trans body, so it has to go somewhere. There is a vent on top of the body of the trans, but most all of the seals can weep some fluid. I would suggest you fire that old girl up and run it down the road. Wash off the trans, and see if the leaks come back.
cparman is offline   Reply With Quote
Old 04-27-2009, 06:14 PM   #4
lks dcvn
lks dcvn's Avatar
Sounds like a plan to me...
Old 04-28-2009, 12:35 AM   #5
Musclerodz
yoke seal bad
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 05-01-2009, 09:49 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Mine does the same thing and its the front yoke seal also...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-01-2009, 10:59 PM   #7
Long Roof
Old School, New Style
Long Roof's Avatar
My trans did the same thing this winter. It was down about three quarts. My rubber trans gasket leaked. When the Jimmy sits for a long time the converter drains down and pushes out the trans pan gasket. Normally fine if I run it a couple times a week. Just so happens that it leaks in the passanger front corner and drips onto the front shaft. I keep a drain pan under the shaft just for this reason.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 05-02-2009, 11:56 AM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
If the transmission fluid is coming out from around the seal on the transfer case, then you have two problems. The transfer case is supposed to be full of 90wt. Gear Oil. What this means if the fluid is running down the driveline coming from the transfer case, you have a bad tranny to transfercase adapter seal and front yoke seal in the transfer case.
A quick way to see if this is your problem, pull the transfer case fill plug. That plug sits lower than the transmission and either mixed gear oil and tranny fluid will come out or strait transmission fluid. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-02-2009, 09:14 PM   #9
jamie72
jamie72's Avatar
i think he has a 203 xcase in his blazer..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-02-2009, 10:03 PM   #10
bouncytruck
SKINNY TIRES RULE!
His truck has a 350/TH350?NP203 combo. The transmission was completely rebuilt right before he bought it.
bouncytruck 1972 K5
