04-28-2009, 07:51 AM | #1 |
Trailers are for BOATS!
Trans problem
Got my truck home, FINALY! Drove it around a little Sunday and to work on Monday. Problem started when I was ALMOST home. I was accelerating when all of a sudden it wouldnt shift into 3rd anymore. Reverse feels kind of shakey as well but primarily it wont shift into 3rd. First I thought the vacc line had come off but it is connected on both ends.
Any advice?
The Rod Barons
C.C. CSA |
04-28-2009, 11:30 AM | #2 |
Re: Trans problem
what does the trans fluid look like. Does it smell burnt' did you check the level of the fluid. did the detent cable slip? did the modulator valve go bad. Lots of places to start. but all cheep and easy to check. I would also look at the linkage. make sure the selector is putting it into drive and not 2nd. Sometimes the linkage gets sloppy.
05-03-2009, 12:17 AM | #3 | |
Re: Trans problem
04-28-2009, 12:12 PM | #4 |
Re: Trans problem
Selecator is fine because if I bump up it goes into neutral. The vaccum line is on the modulator, it didnt blow off I mean. The cable appears to be fine but I will investigate that further when I get home today. Fluid level and appearance is good.
The Rod Barons
C.C. CSA |
04-28-2009, 12:22 PM | #5 |
Re: Trans problem
try changing gears manually from 1-3 wait till you have a good rpm on the truck in 2nd say around 3500 on a mild acceleration then change into 3rd, see if it drops down.
04-28-2009, 01:36 PM | #6 |
Re: Trans problem
Ill try that again this afternoon. It didnt work yesterday
The Rod Barons
C.C. CSA |
04-28-2009, 11:50 PM | #7 |
60-66 Nut
Re: Trans problem
You might look at the filter. It could be plugged up if it hasn't been changed in a while.
04-29-2009, 07:35 PM | #8 |
Resistance is Futile
Re: Trans problem
If this is an auto 3 speed....like T400, you are losing the clutches. Reverse and drive are shared gears. Ask me how I know.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-29-2009, 10:30 PM | #9 |
Re: Trans problem
04-30-2009, 09:18 PM | #10 |
Re: Trans problem
.......'90 SS454.
