Old 04-28-2009, 08:25 PM   #1
bw4sale
bw4sale's Avatar
What's my ratio?
I marked a spot on the driveshaft and then turned my hub and counted the revolutions. My driveshaft only went around a little less that 2 turns to the hubs 1. So, what's my ratio?
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 04-28-2009, 10:00 PM   #2
Green Machine
Green Machine's Avatar
Re: What's my ratio?
Turn the wheel around twice, or if you have the time, turn it 20 times, that will get you a spot on answer. For instance, if you turn the wheel 20 times and the ds goes around exactly 41 times, you have a 4.10 rear.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-28-2009, 10:09 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
You can look on the housing (for Location see the pics below) then go here and look up the code:
http://www.americanclassic.com/paint.htm
You just need the first two or three letters....
LockDoc
Leon
Old 05-09-2009, 08:10 PM   #4
bw4sale
bw4sale's Avatar
Ok, I tried it again and got this
Wheel/DS
10/18
20/37
30/56
I don't understand your math, but according to that would that make mine a 3.73??
BRENT
Old 05-09-2009, 08:23 PM   #5
ERASER5
ERASER5's Avatar
Yes. 3.73. Now put a posi in it, and your golden.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-09-2009, 08:44 PM   #6
How do we come up with 3.73?
3.73 would aprox.3 3/4 driveshaft turns to 1 axle turn.You`re coming up with around 2:1.
Old 05-09-2009, 08:47 PM   #7
Hart_Rod
Hart_Rod's Avatar
For a "one legger" I always multiply by 2......
Hart_Rod is offline   Reply With Quote
Old 05-10-2009, 07:55 AM   #8
hgs_notes
GEARHEAD
hgs_notes's Avatar
Because of the spider gears, if you have one wheel down and not turning, the ratio is half. If you were to roll the axle, both wheels down, the pinion would turn twice as fast. I just did this myself friday and figured it out. I don't think it works this way for a posi axle, but I'm not positive of that.
hgs_notes is offline   Reply With Quote
Old 05-09-2009, 09:35 PM   #9
bw4sale
bw4sale's Avatar
I still don't understand the reasoning, but I would trust it to be a 3.73 long before 1.80.
BRENT
Old 05-09-2009, 10:21 PM   #10
DMARCUM123
I had my check and it came up with a2-1 the friend checking it said was coming up right so i pulled the cover it was a 373
DMARCUM123 is offline   Reply With Quote
