04-29-2009, 11:07 PM | #1 |
PITbut
Starters, mini starters, might want to check this out.
I just kind of stumbled upon this. I dont know if its new news or im just a late bloomer. I have a chevy 454. Its from an 81 chevy. The starter that came with it is huge. My headers literally touched my starter.
I was in the market for a mini torque starter and came across this. Its a starter from a newer chevy. Pt#6944. I took pictures and weights. This is the factory original starter with 2 starts on it. ahah I bought it brand new. I just realized that it wont last long with my headers.. Here we go. Starter#1. Starter weights 20 lbs, is fargin HUGE. Bought 95 bucks. It fits 1981 and on 454s from what i heard. Here is starter #2. As you can see, HUGE difference in weight. This fits my 454 also. 7lbs. Its a magnetic type and supposedly has more torque then the huge original one. Its about 95 bucks also. Side by side comparison Anyways, it now clears my headers VERY nicely and im going to make a little heat shield for it to extend the life of it also.... Just i have never seen this and figured if i could help at least one person by my post, why not.... |
04-29-2009, 11:28 PM | #2 |
Re: Starters, mini starters, might want to check this out.
Im glad to see you found out about it ! I got one on my small block. Just dont forget the heat shield. Those mini starters are alot easier to put in and take out compared to the bulky heavy stock ones
72 C20 Longbed 05 1500 Z71 |
04-29-2009, 11:36 PM | #3 |
Where did you get it at?
04-29-2009, 11:43 PM | #4 |
motor exploder
where'd you get that/what manufacturer is that part # from?
Good find!! thanks for the info!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
04-30-2009, 12:02 AM | #5 |
Better double check me, but I am pretty sure you need some conversion bolts to use that starter, or you risk cracking the block at the starter bolt holes. A friend of mine had this happen to him with his beefy 383, and I am pretty sure it boiled down to the fact that he used the original starter bolts with an 89+ starter.
I am installing one tomorrow, don't know the part number, but I got the starter and the supposed "conversion bolts" for $115.00. If I find out more info, I'll post it here. They are great starters, and call me queer, but they sound pretty cool too |
04-30-2009, 12:19 AM | #6 | |
Ahhh!!! BINGO FOUND IT!! P
Quoted from https://www.s10v8.com/showthread.php?t=1073758867 Quote:
04-30-2009, 12:34 AM | #7 |
1 thing at a time is progress.
Great info here
Alan
Philippians 2:14-16 |
04-30-2009, 12:19 PM | #8 | ||
PITbut
That information isnt truely correct. In the middle 1980s and earlier they were standard bolts and hole sizes. Just after the middle 1980's chevy switched to metric. You need to check the year on the block to be sure.. These will bolt up fine to a 1981 and later. IF YOU USE THE CORRECT BOLTS. Last edited by lyrikz; 07-21-2009 at 07:44 PM. |
04-30-2009, 12:27 PM | #9 |
454 MAKES IT ROAR
Skip White sells em on Ebay.....
http://search.stores.ebay.com/whitep...354947QQsofpZ0
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
04-30-2009, 09:37 AM | #10 |
PROJECT 7DEUCE
Where would one moron go go find the starter and bolts?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-30-2009, 10:49 AM | #11 |
Well, I got mine from Lancaster Starter and Alternator http://www.lancasterstarterandalternator.com, but what you need is starter bolts with a 3/8 thread, and a 10MM shank...
I can only assume that if you called, they could ship the starter and bolts to you. |
04-30-2009, 11:24 AM | #12 |
If you have a GMPP nearby check with them. I bought my mini starter from them and it came with the different bolts and they worked perfect. I dont remember how much I paid, but it sounds about right to what Lyrikz said about $95
05-01-2009, 01:34 AM | #13 |
Installed my starter tonight.... Man, I wish I would have put one on from the start, but like usual, I was being a cheap-ass, and saved $30 when I assembled the thing.
Music to my ears |
05-01-2009, 09:57 AM | #14 |
18 Till I Die
I tried this swap not long ago and found that the starter bolt are too long also, they wont work at all.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
05-01-2009, 11:39 AM | #15 | |
PITbut
One thing that should be mentioned to anyone doing it, is make sure you match up the bolts. Make sure they come out of the starterthe same distance on both starters.... |
09-06-2009, 03:59 PM | #16 | |
PITbut
Man, i installed the starter way back when i posted this. I ordered new bolts that fit correctly and then just left the starter in. I went to start the truck today, and PHWWINNNNG is what i get. ahaha The starter isnt engaging the flywheel. I have the correct bolts, i wonder what im missing... Im thinking of just returning this starter and picking up a skip white one.... For some reason they dont sell the red or chrome ones anymore... Guess i will wait until tuesday to order that up.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
09-08-2009, 02:26 PM | #17 |
Please Subscribe in order to post for ads for sale. Reading the rules and the subscription information is highly recommended before posting. - Josh
09-08-2009, 03:03 PM | #18 |
PITbut
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. Last edited by Josh; 09-08-2009 at 04:11 PM. Reason: removed fs info |
09-08-2009, 03:53 PM | #19 |
Active Member
subscribed!
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
09-08-2009, 04:10 PM | #20 |
PITbut
I have a bit more info.... So basically it doesnt matter the size of the gear on the starter... You just need the correct length and thickness of bolt, then you may have to shim the starter a bit... I have the shims and will update later tonight to see how this works.... I should of known that just bolting it in and starting wasnt going to happen.
09-08-2009, 05:42 PM | #21 |
18 Till I Die
If I go to a wrecker and pull the bolts from a mini starter they should work then? I think You need a trans inpection cover as well since the starter nose is different.
09-08-2009, 06:47 PM | #22 |
You can't interchange the gears cuz we are talking apples and oranges. The whole starter is interchangeable. I have replaced many big 10MT starters with the mini and have NEVER had to shim one. Maybe the extra work is worth it so you can use the good stuff. Shim away. Shims are for misfits and engineering mistakes. It is not your starter guys fault.
09-08-2009, 08:57 PM | #23 | |
PITbut
Any of this makes sense??
09-08-2009, 10:16 PM | #24 |
Greetings,
I have found that our starter is bolted though the bellhousing. Therefore is it possible to install the mini staggered bolt design? Thanks MrBLue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
09-08-2009, 09:50 PM | #25 |
yes, i'm sure your starter guy can figure it out. If the big starter worked without shims then a small one should also. you may want to shim only one side and see what happens. shimming one side will move the gear closer to the center of the flywheel and shimming only the other side will move the starter gear farther away. Not all chineese parts are inferior. Some are of excellent quality and some are junk. I would like to say all chinees stuff is junk, but it wouldn't be true. Just because something is manufactured in China doesn't mean the quality control is suspect. American companies manufacture in China and the parts must still meet specifications. The labor costs are lower there, but if fuel and shipping costs continue to rise I think some of the US manufacturers will start comming home again. Talk to your rebuilder. Not only can he make sure you get a quality part he also has a vast storehouse of knowledge. Sometimes quality costs a little more but it usually only costs more once instead of constantly and causing more damage to other parts costing again, not to mention time. Support your local rebuilder or the only parts left will be the cheap stuff from the big box stores and when the competition is gone the low quality stuff will increase in price. You will also have an experienced ear locally to talk or complain to. Even some of the big catalog companies are selling poor quality parts at inflated prices. Good luck with your starter. Mark
