04-30-2009, 09:38 AM | #1 |
'69 Chevy SWB
Front sway bar Question
Has anyone used this sway bar on ebay? Item # is 160331430419
http://cgi.ebay.com/ebaymotors/1963-...Q5fAccessories For $130 shipped, does this sound like a good deal or would I be better off with a name brand one from some where like brothers or other dealers? The same ebay dealer has a rear for $150 shipped. Last edited by stealthy '69; 04-30-2009 at 09:40 AM. |
04-30-2009, 09:46 AM | #2 |
PROJECT 7DEUCE
Re: Front sway bar Question
Looks like a good deal but the ends of the bar look squished and I am pretty sure that would not mount on our trucks however I am by no means an expert and could be totally way off base..
Of course it could just be a generic pic also..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 04-30-2009 at 09:47 AM. |
04-30-2009, 09:52 AM | #3 |
"the other guy"
it looks like it comes with end links to mount to the controll arm. good deal. ccp has similar deals on the bay right now.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
04-30-2009, 10:03 AM | #4 |
If you end up getting it, report back and let us know how it worked - a lot of us would be interested.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
04-30-2009, 11:53 AM | #5 |
Watch out for your cornhole !
There isn't anything high tech about a sway bar. A 100 plus dollar bar won't be any better than a 20 dollar salvage yard bar with new bushings.
05-01-2009, 09:26 AM | #6 |
'69 Chevy SWB
What bars will fit these trucks as a bolt on. Or I guess a better way to word is, Bars from what other vehicles will fit as a bolt on? I know I've seen on here a mid 80's-early 90's IROC or Z Camaro bar will work on the rear. But what fits the front?
05-01-2009, 09:57 AM | #7 | |
The easiest source of swaybars is off 73-87 models, half ton, 3/4 ton, even 1 tons, plus Suburbans. They bolt right on. The holes are already in your truck for it. Lets face it, a sway bar is a big old 1 inch (or larger) piece of round steel. That's it, nothing special about it. They don't wear out. It's very sensible to get a used one from the junkyard (around here that will run you about 20 dollars). Then, the new bushings are available at your local part store. Moog sells real nice urethane bushings for right at 25 dollars for all the set. So now, you are out 20 for the bar, 25 for the bushings, for a total of 45 bucks. You have a great sway bar and you have saved a lot of money in the process. As heavy as a sway bar is, it wouldn't suprise me if shipping one would cost more than a used one. Why buy new ?
05-01-2009, 11:13 AM | #8 |
I have this bar and wish I would have got one from a junk yard that bolts to the holes already in the lower control arm, the angle of the legs in the bar make it a pain to line up the end links, just my oppinion but I think a stock bar that comes in straight to lower contol arm vs. comming out at an angle is better fit for these trucks
05-01-2009, 12:23 PM | #9 |
18 Till I Die
Are the 73-87 truck brackets the same as well? The frame brackets and the lower control arm ones? ...Is it a direct swap?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
05-01-2009, 09:04 PM | #10 |
The brackets are exactly the same. It's a bolt on deal.
You will need a 2wd bar for your 2wd truck.
05-01-2009, 10:08 PM | #11 |
'69 Chevy SWB
great thanks for all the info
05-02-2009, 01:55 AM | #12 |
motor exploder
If you're after performance and are gonna get a junkyard one, get one from a 1 ton, they're bigger in diameter. (1.25" I believe??)
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
