I've got my 72 GMC Shortbed Fleetside at the shop.
One of the things my mechanic asked me was to post on the board about this problem: When the lights are off and the Brake is applied, the Instrument Panel Lights- Light up. Now they also go on as they should when the Headlight switch is pulled out and I notice, NO DIMMING of the Instrument Panel Lights when the Brake is applied. I seem to remember a similar problem on my 67 C-10, but that was so many years ago.............. (and another Mechanic). I thought some of the better informed 67-72 owners might know...like " Oh hell yea thats a common problem on those Trucks. Just take XXXXX and do XXXX and your good to go". I wanted to hopefully find out what it is a have my mexchanic remedy it BEFORE I pick it up on Monday. Any Links/thoughts/opinions would be appreciated! Roger "RATIKLE" ![]()
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" Last edited by wwotr; 04-30-2009 at 04:08 PM. |
sharp as a marble
![]() Join Date: Jan 2007
Re: Instruments panel lights up when brakes applied?
my first thought is that you have a turn signal bulb/brake light bulb that if back feeding voltage thru the instrument cluster. I have seen this a time or two. Visually check all of the bulbs to be sure that there is not a damaged element in one of them
It could be a bad bulb, or more likely a bad/missing ground in the tail light harness.
Tim |
Gone to greener pastures
![]() Join Date: May 2007
I'd start out by checking ALL your grounds.
I know it sounds stupid, but a bad ground in one place can do really weird stuff in a totally different area. Don't just "eyeball" the ground connections. Take them apart & make sure everything is clean & shiny for good connectivity.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
I am new to this forum and to the older trucks but I have been an import mechanic for 15 years.I have seen single element bulbs in dual element sockets and vise verse cause many lighting problems.
That is by far the easiest thing to check.Another way to tell is see if your parking lights are coming on and you just don't realize when you hit the brakes.Just my 2 cents.Hope it helps. AJ |
This use to happen once in a while at dealerships on new cars. Some yo-yo would put the 1156 bulb in the 1157 socket. When the brake is applied, the power back feeds the parking light circuit including the dash. Sounds like your problem.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Usually means the wrong bulb was put in the taillight socket. I'd start there for sure. See it alot around here for some reason.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
its all about the +6 inches
like many of the others said, I would start with 2 brand new 1157 bulbs in back.
The ground thing, not likely. Easy enough to fix though, but the electricity would take the path of least resistance, and that would be through the back up lights 9 times out of 10. See it all the time on trucks at work. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
When I first read the post, I was thinking I've never heard of a mechanic asking his customer to post on the web looking for repair advice. Seems like it would undermine the customer's confidence.
I never heard of that either. If I have to educate my mechanic, he'd better have a particular machine that I don't, like a tire machine. A parts counter guy, I don't mind educating. Nicely. If I start getting warm, it is time go to the next store.
so true! Esp for something that is more likely than not, just a bad bulb.
Was anyone else learning this stuff in high school? |
![]() Join Date: Nov 2007
I posted about this not too long ago. I had the same problem put some new bulbs in the taillights and problem solved
Thanks to ALL of you who came out of the woodwork to help me with this problem.
Upon CLOSER INSPECTION, I found : Drivers Side Tail Light: No 1156 Back-up Bulb in the Socket. Passengers Side Tail Light: An 1156 Bulb in the 1157 Socket. I'm putting new lenses/Bulbs when I get back into town on Wednesday (next week). On top of THAT, when I took out the old ("Under Dash Stereo"), it had 3 Ground Wires that were screwed in under the Dash. I didn't pull them out yet, because I THINK they may go to some of the Gauges. I'll need to take a look at that as time alows. Thanks Again to EVERYBODY! Roger
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
Tags |
1972, brake lights, gmc, instruments |
