05-01-2009, 04:22 PM | #1 |
Cultural Infidel
Disc vs. Drum brakes
I would like to here from those that have experiance driving trucks with both disc front/drum rear and drum front/rear. What are the pros and cons of each.
Thanks -Mark
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold! It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
05-01-2009, 04:25 PM | #2 |
Gearhead and audio junkie
Re: Disc vs. Drum brakes
My 69 has drums all around and it stops pretty well P/B. Of course i just had my entire brake system redone. However for drums they stop pretty well, never had any bad brake fade. Of course Discs will outstop drums all around but if your tight on cash a well maintained drum system should be plenty efficent
05-01-2009, 04:34 PM | #3 |
Between Trucks...
X2
Beat it to fit, Paint it to match... |
05-01-2009, 04:39 PM | #4 |
i have drums all around on my 69 shortbox. power brakes..
if your not trying to road race you truck, they are fine. they will stop really hard real good, once. if you try to stop real hard real fast more then once without letting them cool off is when you start to have problems. living in the mountains, or towing big loads can be tough as you get prolonged amounts of brake use (as in your riding the brakes for long distances) and they will heat up alot faster then discs do, causeing brake fade..
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
05-02-2009, 10:53 AM | #5 |
Cultural Infidel
Thanks for the replies. Now if I find a truck with drum brakes, I won't be in a rush to change to disc.
-Mark
05-02-2009, 12:06 PM | #6 |
20' Daredevil (Ret)
Drums will be fine. That said, I'm glad I have front discs -- I live in hill country and sometimes the old girl has carried some very heavy loads. Five miles of very steep downhill with tight corners and a few thousand pounds in the bed will get your attention...
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
05-02-2009, 01:23 PM | #7 |
Cultural Infidel
Not a lot of hills here in FL, so my list of "must haves" for my next truck just got smaller.
05-02-2009, 01:31 PM | #8 |
Eat My Rust
Drums, mine were always pure suck. In the few drives I used them, they had little stopping power until they rapidly decided to stop the truck. Which usually meant locking up the front tires. Needless to say the truck now has 12" Disk brakes now that it's on the road.
Emergency stops with drums, is a joke I hear. Last edited by texanidiot25; 05-02-2009 at 01:31 PM. |
05-02-2009, 01:39 PM | #9 |
20' Daredevil (Ret)
^^ I love discs and am not a fan of drums..... but something was wrong with yours. Properly set up, they should work just fine under most circumstances, including panic stops.
05-02-2009, 01:51 PM | #10 | |
05-02-2009, 02:02 PM | #11 |
Eat My Rust
Good drums/shoes and plenty of fluid.
Their just completely inferior. They can't stop has hard with out locking, or react as quick to peddle modulation as disks can. And as mentioned, heat is a factor. I've never noticed that drums get hotter than disks until I started driving this truck Even with the Drum MC the truck out stops the OG Drums. Last edited by texanidiot25; 05-02-2009 at 02:03 PM. |
05-02-2009, 02:08 PM | #12 |
Eat My Rust
And the 300 or so spent on 73-87 disk brakes with new rotors, BJs, calipers, and pads is well worth the extra safety and control. 12" x 1.5" Disks stomp nice and hard.
05-02-2009, 05:50 PM | #13 |
I look at what for, and how much is the truck used. I really had to wrestle with this same thing, but I figured that the cost doesn't justify the gain, since I only put about 500 miles a year on my truck and I don't tow anything. HOWEVER, if I go though with my future plans to build a Quarter miler (70 Nova, like I had as a kid) again, I'll go the route of 4 wheel disc brakes for safety. Hope this helps, Cnut
05-02-2009, 05:59 PM | #14 |
well there is always the slotted & drilled drums route for extra cooling...
05-02-2009, 06:05 PM | #15 |
drums are ok for around town driving, but when your on the highway give yourself room to slow down.
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
