05-02-2009, 08:40 PM | #1 |
I have a 12 bolt rear
Today I counted the bolts on my rear diff.. it's a 12 bolt. Is that something special? I KNOW it is not posi.. can I convert it to posi, or would it be best to buy a positraction rear end and swap it?
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 ) 2001.5 VW Passat beater 1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint |
05-02-2009, 08:47 PM | #2 |
Re: I have a 12 bolt rear
Yea, you can just buy a posi unit for it.
05-02-2009, 10:47 PM | #3 |
thanks for the reply.
I don't know what ratio I have, so I jacked up the rear and turned the driveshaft by hand, but I only get about 1 and 1/2 turns from the driveshaft for one complete tire rotation.. I get the feeling that I need to multiply that by 2, so I assume I have a 3.08:1?
05-03-2009, 12:59 AM | #4 |
Pull the cover off and have a look. The numbers you are looking for are stamped on the ring itself. For example 38:10. This would be a 3.80 ratio. Now that you're this far, you might as well pull the axles and put in that posi!
05-03-2009, 09:13 AM | #5 |
If you will look on the forward side of the passenger side of your rear axle, you will find a (3) digit code. It will be (3) capital letters. Once you have that code, go to this link and then "Axel Codes". It will tell your what your differential is. A lot easier than pulling the cover and counting teeth.
http://www.americanclassic.com/paint_test.asp |
05-03-2009, 09:29 AM | #6 | ||
It's just not as easy as that. You really should have a Pro install something like that.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. Last edited by LONGHAIR; 05-03-2009 at 09:31 AM. |
