05-02-2009, 08:55 PM | #1 |
static drop ???
What does it mean when you static drop these trucks and could you guys post the parts that are included with it.Thanks
If it ain't a chevy,I don't want it |
05-02-2009, 09:54 PM | #2 |
Re: static drop ???
Static drop just means that it's not a variable drop such as you get with airbags or hydraulics. A static drop is usually achieved by using drop springs, shackles, and spindles. There are several different combinations you can use to achieve your preferred drop.
1967 C10 LWB 454/TH400 1971 C10 SWB 1984 C30 LWB Dually 454/4 spd 4:10 2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison |
05-02-2009, 10:15 PM | #3 |
Re: static drop ???
Thanks 66 I thought it was something different,then what you explained...lol
05-02-2009, 10:22 PM | #4 |
Tot Roddin'
Re: static drop ???
nsuengineer06... said it about right.
A static drop would consist of the suspension parts that are essentially on the truck from the factory, just shorter. The parts used on this type of drop may include any combination of the following: Spindles (Drop/Stock) - if the truck is factory drums up front and you use drop spindles you must convert to front disc Springs (Drop/Stock) Front/Rear Shock Relocators (for certain inch drops) Adjustable Panhard Bar Drop Shocks Modified a-arms (tubular/dropped/sectioned arms) Pros include cheaper that air ride; Cons include the inability adjust for certain terrain (speed bumps) Any other type of drop will consist of air or hydraulics, however hydraulics are IMO on their way out as a bag setup is much easier and cheaper to install. A bag setup will consist of any of the items listed above (aside from springs) but also needs the following: Bags Air management (can be done by a stand alone manual fill system as well) Pros include the inability adjust for certain terrain (speed bumps); Cons include the price (possibly...), and a little more know how to install
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
