05-04-2009, 09:11 PM | #1 |
Picture of manual transmission crossmember and support
I like to convert my 1971 from th350 to manual 3 speed transmission. Do you have picture of crossmember and support(installed) that I need to make the conversion . Can I reuse my automatic crossmember to support the rear end of the manual transmission? Thank's, François
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
05-04-2009, 10:03 PM | #2 |
Watch out for your cornhole !
Re: Picture of manual transmission crossmember and support
No need to convert the crossmember. You can reuse your existing auto trans crossmember and mount under the new standard transmission.
05-04-2009, 10:05 PM | #3 |
you don't have to add crossmember to support the rear of the engine or bell housing?
05-04-2009, 10:36 PM | #4 |
Not needed. As a matter of fact, starting in 73, GM went to the rear crossmember only and did away with the bellhousing unit on all trucks.
05-05-2009, 05:28 AM | #5 |
Thank's for the info firefighter!
05-05-2009, 10:04 AM | #6 |
Just out of curiosity is there an advantage to switching from the bellhousing crossmember to the auto crossmember? I know the auto crossmember bolts on the tailhousing of the tranny so it should cut down on torque to the carrier bearing. Just thought id pose the question.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
