Old 05-06-2009, 02:02 PM   #1
jbird76
my 70 project
Here is my project:
I have a 1970 c20 with a 350 and a unoriginal 4 speed. I am ditching both. I currently own a 99 suburban with a replaced L31 5.7 vortec with less than 7,000 miles. I also have found myself an nv4500 out of a 95 pickup. My plan is take the engine, harness, FI, etc. out of the suburban and completely transplant it into the 70. Then mate it up with the nv4500 and get a set of front disks out of a later model 3/4 ton truck.
I have two questions:
1. How will I handle the gauge situation? I know I need to go to a chip of some sorts, and I was looking at the Jet, but I really have no idea about chips, I have only done older carbureted things. Can I just hook up my factory gauges? get a set of aftermarket ones? Is there someone who makes a set for my set up, but is meant to go in an older truck?
2. How can I work the AC? The two years have different systems, but I am hoping I can use everything from the 99 in front of the firewall, and mate it up with what is left in 70. I am guessing that may be wishful thinking though.
Thanks in advance.
jbird76 is offline   Reply With Quote
Old 05-08-2009, 11:11 AM   #2
jbird76
Re: my 70 project
anyone?
Old 05-08-2009, 12:40 PM   #3
nightmare
nightmare's Avatar
Re: my 70 project
Thanks in advance.
Lets see if i can help any.
1. You will need to get different gauges for some of them. The speedo on the new setup is electrical, whereas the old one is mechanical. Also the oil pressure sending unit should be electrical too. You should be able to re-use the old sending tube on the new engine, and should be able to keep the stock gauge. As for the water temperature, that should still work. Now for the alternator, you'd be going to an internally regulated setup, instead of the externally regulated setup you have now. There are wiring diagrams around that show how to do this.
2. The best thing would be to leave the stock stuff on the truck, and use the newer compressor. you will need to either get a set of hoses made to hook the compressor to the condenser, or see if anyone makes those hoses already.
I hope this helps make things a little clearer.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
