Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-06-2009, 08:09 PM   #1
jsnook72
jsnook72's Avatar
1994 s-10 385ci 480 horsepower
Does anybody know how to get the power to the ground NEED SUGGESTIONS
jsnook72 is offline   Reply With Quote
Old 05-06-2009, 08:35 PM   #2
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: 1994 s-10 385ci 480 horsepower
Lots of weight in he back...got pics?
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 05-06-2009, 08:52 PM   #3
jsnook72
jsnook72's Avatar
No not on this computer it is my friends truck i helped him build it i will get some though
Old 05-06-2009, 09:05 PM   #4
BarryB
BarryB's Avatar
one proven way is to turn down your pinion angle. 5 degrees if i remember correctly. Seen a stock sprung S10 runs 12s with the diff set up that way.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-07-2009, 08:14 PM   #5
jsnook72
jsnook72's Avatar
well we are getting 11.88 now but the rear jumps the first 60ft or so
Old 05-08-2009, 11:42 AM   #6
BarryB
BarryB's Avatar
The S10 I am talking about never did jump it would squat and go. He wasn't running as much HP as you but with the pinion angle down the diff doesn't wrap like it does in stock position. It would be an easy fix. just loosing up the U-bolts and shim the diff down and give a try. Unless you have already done this. Then you'll need to get some kind of traction bar set up under there.
Two rules in life.
Old 06-06-2009, 02:10 PM   #7
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Does the truck have an anti-hop shock in it stock? It's a single shock on one side of the rear end that is horizontal and attaches to the frame to prevent wheel hop. I his doesn't, you might want to start scouring junkyards for the shock and frame bracket. The axle bracket should already be on the rear end.
My 03 4.3/5speed 2wd came with one and it helps with wheel hop.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 06-06-2009, 04:44 PM   #8
corn
Leaf spring rear?
corn is offline   Reply With Quote
Old 06-07-2009, 03:50 AM   #9
big_c_snow
...AWD? that might help a bit... heh
94 Ford Aerostar AWD
Which is useless in Florida...
86 FJ1200
Daily Driver
big_c_snow is offline   Reply With Quote
Old 07-01-2009, 02:39 AM   #10
ZZ4Blazer
Good shocks, caltracs, and MT drag radials.
Seen plenty of trucks hooking hard on that simple combo, without more than the battery in the bed. What do your 60ft's look like?
ZZ4Blazer is offline   Reply With Quote
Old 07-01-2009, 10:10 AM   #11
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
need more info to really help ya.
IE, what is your suspension and driveline set-up. Caged or not? etc etc
and this is prolly a better place to get better answers
I know it's a dime, but still:
http://67-72chevytrucks.com/vboard/f...splay.php?f=60
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 07-01-2009, 09:20 PM   #12
The Big Green
That's not a LOT of hp, but by no means is 480 slow. Lots of good help here. I know of a '90ish 454 S-10 that hooks great! It's a built frame with wide slicks. I'd say tilt the rearend and ladder bars, or tilt rearend and slicks and go from there. When I say slicks, not full blown slicks, more a dot street radial. I just biult a '91 with a LOT of hp. I'll be back halfing mine very soon, it scares the crap outta me!
The Big Green is offline   Reply With Quote
Old 07-14-2009, 10:00 PM   #13
teamcosmo
Get yourself a set of cal tracs. My buddy has a 91 with a smallblock it runs mid tens. He has belltech drop springs and cal tracs and that hooks all day
teamcosmo is offline   Reply With Quote
