Old 05-11-2009, 11:39 AM   #1
prg machine
prg machine's Avatar
Eaton Rear axle pinion seal.
Has anyone changed the pinion seal on one of these? After I remove the Yoke does the seal come out with the front retainer plate?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 05-11-2009, 03:02 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: Eaton Rear axle pinion seal.
When I thought my pinion seal was leaking I posted this thread that will help you out - ended up not being a pinion problem for me so I didn't have to do anything further.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-11-2009, 04:37 PM   #3
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
i have done this on my rear end. as i remember, it does not come out with it. its a real easy swap.
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
Old 05-11-2009, 05:52 PM   #4
Wrenchbender Ret
After removeing the yoke remove the retainer & you can replace the seal in the retainer. It takes a thick cork gasket behind it but you can use a thick bead of RTV.
Wrenchbender Ret is offline   Reply With Quote
Old 05-13-2009, 11:42 AM   #5
prg machine
sounds like 2 different answers. If I got it......I remove the yoke.....remove the retainer and the seal is pressed into the retainer and I have the retainer out to take to do it at the work bench???
383 .040 over
Old 05-13-2009, 04:49 PM   #6
Shaky
Six in a row makes it go...
Shaky's Avatar
It's really worth getting your paws on an Overhaul Manual if you can.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 05-13-2009, 09:41 PM   #7
hicktownhotrodder
Rollin Coal
no. my bad. Wrenchbender Ret was right. take the retainer out and the seals in there
God-Made-Chevy
Old 05-14-2009, 12:58 AM   #8
prg machine
Thanks a bunch guys. Now to order up the seal and get the pen oil out and let it soak up.................I have had to use a chisel as a driver to get some of these nuts loose before on the Jeeps when things got brutal.......then just replace the nuts since they are not that expensive.
383 .040 over
Old 08-22-2009, 01:34 PM   #9
prg machine
Finaly got tired of the leak so I called and there were 2 seals at the store . 20 bucks. Now to get around to actualy doing it!!!! Who has had to actualy do the speedy sleave repair and how much of a pain is that if i need to get into it???
383 .040 over
Old 09-21-2009, 09:23 PM   #10
prg machine
anyone?
383 .040 over
Old 09-21-2009, 09:49 PM   #11
prg machine
Everything I am finding indicates that the preload on the pinion bearings happens with a spacer between the 2 inner races. Correct me if i am wrong... Maybe the rear end just gets pretty warm????
383 .040 over
Old 09-21-2009, 10:12 PM   #12
prg machine
I went out there under the truck and with e-brake on and truck in gear I can just rotate the driveline slightly clockwise/counterclockwise indicating the slight gear clearance that it has always had. I can turn the yoke effortlessly. nothing binding, just like it was when I checked it before bolting up the driveline to the yoke . I think the heat thing is just normal.
383 .040 over
Old 09-21-2009, 11:02 PM   #13
prg machine
ttt
383 .040 over
Old 09-22-2009, 11:42 AM   #14
prg machine
Bearing housing barely warm this morning.....................brake drum hot! Dragging brake.............Did i tweak something with E-brake on and torquing up the pinion nut??? I used a yoke tool to hold it when tightening nut.
383 .040 over
Old 09-22-2009, 12:28 PM   #15
Eichorst69
The Eaton is pretty simple. The preload on the pinion is controled by the pinion shims. If all you did was replace the pinion seal and did not remove the shims then just retorque the nut to about 220 ft lbs. You should be able to turn the pinion back and forth freely between the backlash. The shims also have an effect on the ring gear back lash. The retainig plate gasket won't make a difference.
Once I ran into a problem when I used a different yoke due to the original yoke having grooves where the seal makes contact, apparently there was a slight difference which caused the preload to be to tight so I had to change the shims. Hope this helps.
Eichorst69 is offline   Reply With Quote
Old 09-22-2009, 03:37 PM   #16
prg machine
Yea it is running just barely warm now.......maybe had to take a set. The drag feeling is a dragging brake.
383 .040 over
