Old 05-11-2009, 12:37 PM   #1
BMSJaX
BMSJaX's Avatar
Kick panels I made this weekend
Took me a couple hours on Saturday to make the frames, Sat. night to let them dry and 30 min Sun to paint and install. Not too bad and cost me $0!!! Thats the best part! Just used some 1/4 plywood, some 1x2, an old t-shirt and some fiberglass resin.
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 05-11-2009, 02:13 PM   #2
slepysal
slepysal's Avatar
Re: Kick panels I made this weekend
Nice , so you used the t shirt in stead of fiberglass cloth ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-11-2009, 04:16 PM   #3
BMSJaX
BMSJaX's Avatar
ya, I only had enough fiberglass for one but figured doing one fiberglass would be a waste. it didn't dry as hard as it would with fiberglass but the t-shirt works great!
Old 05-11-2009, 04:31 PM   #4
slepysal
slepysal's Avatar
any pics of your mold ?
Old 05-11-2009, 05:22 PM   #5
BMSJaX
BMSJaX's Avatar
didn't use a mold but here's how i did it. i used a piece of cardboard to make the template for the base first.
Old 05-11-2009, 06:37 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
Now that's custom right there!
Old 05-11-2009, 04:50 PM   #7
jchav62
1962 C-10
jchav62's Avatar
That's awesome!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-11-2009, 08:14 PM   #8
Frizzle Fry
Frizzle Fry's Avatar
Just don't kick your kickpanels With just one layer of cotton they won't take much of a beating. The t-shirt does make a good base for the shape though.
Frizzle Fry is offline   Reply With Quote
Old 05-11-2009, 08:21 PM   #9
MEANlowGREEN
Registered Asphalt Offender
MEANlowGREEN's Avatar
Thumbs up Re: Kick panels I made this weekend
I did the same basic thing on mine, used an old t-shirt for shape but then I laid fiberglass cloth strips over it 2 or 3 layers thick. Yours look great. I hope they hold up well for you! Keep up the good work!
It's not too low unless the tires won't reach the ground anymore!
1963 C10 Short Fleetside Bed Big Back Glass
1974 C10 Short Stepside Bed
1982 S10 Shortbed 350 EFI V8
http://67-72chevytrucks.com/vboard/a...hp?albumid=140
http://www.hubgarage.com/mygarage/MEANlowGREEN
http://www.motortopia.com/garage/cars/MEANlowGREEN
http://www.myspace.com/jcsmeed
MEANlowGREEN is offline   Reply With Quote
Old 05-12-2009, 12:32 PM   #10
BMSJaX
BMSJaX's Avatar
Ya my buddy said the same thing last night... didn't think about it being too thin. This is my first try and I'm sure I'll redue them at somepoint so next time i'll use the fiberglass cloth over the shirt. now you resin the shirt then each layer of fiberglass, correct?
Old 05-12-2009, 12:43 PM   #11
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i did mine with fiberglass i didnt think about a t shirt the fiberglass didnt form to the shape too well so i covered it in carpet
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-12-2009, 01:03 PM   #12
MEANlowGREEN
Correct, I dipped each 2X6 or so strip of fiberglass cloth in resin before applying and then brushed resin over top of each piece as I laid it. You are definitely on the right track, keep up the good werk! You should be able to scuff up what you have done so far then apply fiberglass cloth over top of it. I can't guaranty the two layers won't de-laminate since the old has fully cured but as long as you scuff up the old work I think it should bond well.
Old 05-12-2009, 02:30 PM   #13
joe231
joe231's Avatar
any of you guys use the kitty fur? (i think that is the slang anyway)
it is fiber mixed in with resin, think it comes in gallon cans. saw it on tv, they did the fleece or t-shirt stuff then covered it with the kitty fur....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 05-12-2009, 02:35 PM   #14
MEANlowGREEN
I've used it. It works great in certain situations. I would only use it to build shape in this circumstance and similar situations over a base of fiberglass fleece (or an old shirt!) and fiberglass cloth. You generally use kitty hair for the same types of repairs you would use plastic filler aka bondo for, but when you want greater strength than standard plastic filler has.
Oh yeah, true fiberglass fleece is stronger than a resin soaked t-shirt so if that were used you could probably skip straight from fleece to kitty hair. I still doubt I would do it, but I imagine it would be okay.
Old 05-12-2009, 03:14 PM   #15
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i have used that type of fiberglass for bodywork it works great
its hard to sand but it lasts longer than the plastic filler
Gage
Old 05-12-2009, 04:31 PM   #16
joe231
joe231's Avatar
that is what I have seen done on several tv car shows....
CHEVY ONLY
Old 05-12-2009, 07:58 PM   #17
protrash64
Resistance is Futile
protrash64's Avatar
Here are the panels I made for the 'burb....they are pretty solid when complete. I used short strand reinforced fiberglass resin for finishing...then some Rage before paint.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-12-2009, 08:00 PM   #18
MEANlowGREEN
Great work protrash64! Those turned out great.
Old 05-12-2009, 08:04 PM   #19
protrash64
protrash64's Avatar
Thanx Mean low!!! It was fun....I may re-do them in the future as I should have placed the speakers a little higher in the panel. No big deal and they work perfectly as planned.
Old 05-13-2009, 12:16 AM   #20
Captainfab
60-66 Nut
I've not heard of 'fiberglass fleece' before, just cloth and matt. Can it be found in the same places or is it a specialty item?
Old 05-13-2009, 01:27 AM   #21
muddpile
muddpile's Avatar
Fibreglass fleece is I believe regular fleece, which is what I used on my kicks, the same stuff they make jackets and blankets out of. It's thick and dries hard. Lots of nice stuff on here guys!
muddpile is offline   Reply With Quote
Old 05-13-2009, 05:41 AM   #22
MEANlowGREEN
Yes, it is just plain fleece used for molding then soaked in resin. There is no fiberglass in the fleece, I just called it (fiberglass fleece) simply because of it's intended use.
Old 05-14-2009, 12:20 AM   #23
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
That's awesome. and way down the road...lol
82 Chevy Blazer 4wd.RIP
1965 Chevy C10,350V8
Get it reliable,then puttin' it in the weeds..
"Old truck, all new headaches."
hAetWagon is offline   Reply With Quote
