Old 05-12-2009, 05:49 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question Speed Warning Gauge Cluster Pic Request
just picked up a near PERFECT speed warning gauge cluster. however, it did not include the ridiculously expensive buzzer and harness. I have found an affordable buzzer @ Cheyenne-Super Man and a new repop harness, but would like a pic of the back of the gauge cluster to determine where the buzzer mounts and how the harness is routed. the buzzer does mount on the back of the cluster tin, correct?
could someone post a pic??
thanks gang!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-12-2009, 05:58 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Speed Warning Gauge Cluster Pic Request
The buzzer mounts on a bracket on top of the column. Just a single wire to the back of the tin. I can take a pic later if you still need it. Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-12-2009, 06:19 PM   #3
tcb-1
tcb-1's Avatar
Eric,
could I trouble you for a pic of the column mounting?? I did figure out that the brass mounting pin on the back was some type of grounding lug, but couldn't figure out where the buzzer mounts.
Doug
Old 05-12-2009, 08:51 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Here is a couple pics of an original speed warning buzzer mounting.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 05-12-2009, 08:56 PM   #5
teeitup
Just like to part out trucks!!
teeitup's Avatar
All the ones I've taken off were mounted on firewall like Rob's pics, Not saying Eric hasn't had some with a bracket. GM did some things different in some of there assembly lines.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 05-12-2009, 09:32 PM   #6
into69z
"brand new second-hand"
into69z's Avatar
TCB-!-I too am working on a speed warning dash and have some of the same questions you have-I did not understand what that brass looking washer was for-you said a ground( i think) and I would guess it's a ground for the speedo?would the ground for the dash cluster do the same thing or is there an additional ground to that odd brass washer? I agree, pictures or a diagram would be helpful. Do you know if cheyenne man has anymore buzzers? Thanks for any help!
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 05-12-2009, 09:51 PM   #7
71 super
71 super's Avatar
If you look closely at the white needle (the set needle on the speedo) there is a small wire that grounds out when the regular needle crosses or comes into contact with it. This causes the circuit to close and the buzzer to go off. The brass connector is one pole of the circuit with the rest being located in the buzzer/relay. Instant buzz . All of the setups I have seen have mounted onto the firewall as others have stated. As far as the buzzers seat belt buzzers from same year cars are relatively the same -they will work but have an extra pin, camaros came with speed alerts as did corvettes so your options are a little more broad than you might think. Almost everything is repoped for camaros and vettes including the correct type knob and retaining nut. The cable for the cars is about 6 inches longer than the truck units but will work without a hitch. They will run approx. $35 from Classic industries and other suppliers. Hope this helps, Harold
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-12-2009, 10:17 PM   #8
too much stuff
Roadtrip!
The one i just recently pulled from an original truck and it was listed on the spid, was mounted on the "hoop" bracket over the steering column. The only thing i can think is the truck was a 69. I think the one i found before that was on the firewall. (that was a 67) The 69 also had 2 screws in it. So i am unsure of what is correct now.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 05-12-2009, 10:05 PM   #9
tcb-1
tcb-1's Avatar
Thanks a BUNCH gang, especially you Rob!! perfect pic. that will at least get me started. as stated, I pcked up a repop harness at Classic Parts and it looks really well done. just need to figure out where that darn buzzer mounts.
I don't want to spend upwards of a $100 on evilbay for an original buzzer, so going for a repop there as well.
used to be a easy pulling my gauge cluster, but now I have the main harness, the s.w. harness, the oil line, the tach harness, and the vacuum gauge tube. I don't think I'll be taking it out again anytime soon!!!!
again, that guys for the help!!!
Doug
Old 05-13-2009, 08:18 AM   #10
tcb-1
tcb-1's Avatar
I think the buzzer was placed anywhere the assembly line worker could get his/her hands. I've looked through the factory assembly books and found zilch on where the buzzer was mounted. however, it was probably listed in a special assembly line bulletin. however, it could have just been the luck of the draw??
but good info here guys, I appreciate the help!!
Doug
Old 05-13-2009, 08:03 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Okay Doug... we need pics of this thing!
I hear a FAQ in the works...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-13-2009, 09:01 PM   #12
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Here are some pictures of a factory harness and how it connects to the cluster (from a '67 CST and the buzzer was mounted to the firewall as pictured above):
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 05-13-2009, 09:33 PM   #13
tcb-1
tcb-1's Avatar
a-ha! great pic badpeanut! yep, that how mine looked before I tore it down to bare bones. I didn't have the harness, but with your pic, I can at least compare the length of the wires on my repop. thanks!! rep points!
Nate,
you know me. the minute I got it, I started the tear down and cleaning. the gauge faces are the cleanest I have ever seen and the speed warning is tight and works like a charm. I am going to have to find a way to adapt it to my tach/vac cluster in the truck now..
which brings me to a question for all who have worked on these.
I need to install a ground post on a tin that never had one mounted on it. this is the post that connects the speedometer, through the tin, to the wiring harness.
Doug
Old 05-14-2009, 12:44 PM   #14
71 super
71 super's Avatar
I can email you a picture of mine if you will pm me. I can't for the life of me post pics or I would. Harold
Old 05-16-2009, 08:40 AM   #15
chas350
does the dash have a warning light also? can a 1970 up have one of these?
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 05-16-2009, 02:36 PM   #16
tcb-1
tcb-1's Avatar
chas,
they were only installed on '69 and below. the cruise control option sort of nixed the idea....
no, there wasn't a visual warning on the cluster, only and audible buzzer located approx. in the area Rob has shown in the pics above.
Doug
Old 05-16-2009, 05:03 PM   #17
chas350
I have that exact box (looks like a relay or flasher) on all my trucks, 3-1970 and 1-1971. the wires go to the fuse box though.... what is this then? did they have a door open buzzer?
I will post pics of mine to compare.
chas
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 05-16-2009, 05:29 PM   #18
chas350
Here is the pic of my mystery part lol from a 70 k10
3rd pic is from 70 c10
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 05-16-2009, 06:38 PM   #19
tcb-1
tcb-1's Avatar
that there is a genuine 100% headlight relay.
Doug
Old 05-16-2009, 06:52 PM   #20
chas350
Ahha! Ok, now I see the light! I studied the under dash pics above and see the speed warning buzzer mounts higher.
thanks
quote by LEEVON
70 K20 long fleet
98 G3500 work van
