05-14-2009, 04:08 PM | #1 |
Hydro Boost / Steering hoses and ???'s
Getting ready to put the plumbing to the new hydro boost system and need some tips form you guys.
Hose Type – Would like to know if there is a stainless hose that I can use on both the high and low pressure side? Fitting Sizes – Would anyone know the fitting sizes that go into the steering box and the one into the back of the pump? Filter – Was thinking of running a remote oil type filter unit that mounts to the core support. I am assuming I can use the regular spin on type filter and push the power steering fluid through it with no extra strain on the p.s. pump. I have heard that hydroboost units do not like contaminated fluid. I believe the filter should be fed off the low pressure side? Cooler – Really see no need to run a cooler since this is a street driven only truck Any other tips guys thanks
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years |
05-14-2009, 04:26 PM | #2 |
That's right, it's Copper!!
Re: Hydro Boost / Steering hoses and ???'s
I used stainless hoses for both sides on mine. I don't remember what the sizes were for the fittings, I don't remember how I found out. I didn't use a filter on mine either.
Good luck, I wish I could be more help.
Tom: 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
05-14-2009, 04:34 PM | #3 |
This is the hose I used. http://store.summitracing.com/partde...5&autoview=sku
Tom: 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! Last edited by fastom; 05-14-2009 at 04:35 PM. |
05-14-2009, 04:42 PM | #4 |
I just found the website I used to get everything I needed to plumb my system. These guys were very helpful. http://www.hydratechbraking.com/prod...cessories.html
05-14-2009, 04:45 PM | #5 |
I called Hydratech and they were able to help me with what fittings I needed. I assembled all the hoses myself, very easy to do. The hardest part was getting all the fittings right.
I think the hose size is 6AN.
Tom: 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! Last edited by fastom; 05-14-2009 at 04:47 PM. |
05-14-2009, 04:50 PM | #6 |
Here's a picture.
05-14-2009, 04:34 PM | #7 |
Thanks Fastom, do you have any pics
05-14-2009, 04:38 PM | #8 |
What AN size did you use? Did you buy and assemble all of it yourself, I was thinking I was going to have to have it made somewhere with the crimped ends. I did not know that the regular AN fitting would hold up to the high pressure side.
05-14-2009, 04:56 PM | #9 |
Very Very sweet looking engine bay
05-14-2009, 05:10 PM | #10 |
Excellent, they look like they have everything I need
Might also ask them about the filter idea thanks
