Old 05-18-2009, 09:05 PM   #1
sjarrett71
sjarrett71's Avatar
Shaved Cowl
I know if you don't put the screen in gunk will accumulate and cause rust. The factory obviously put the slots in them for a reason. What was that reason? What are the pros/cons to shaving a cowl and removing the slots?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 05-18-2009, 09:18 PM   #2
Sammy
Re: Shaved Cowl
I have always wondered why too. Figured they thought it would suck more air through at one time. But that doesn't add up does it? Adding the fine mesh screen under the cowl would solve the trash problems. Drilling a hole or enlarging the hole for a drain would solve the rust issues.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-18-2009, 10:52 PM   #3
KB71C10BBSUPER
KB71C10BBSUPER's Avatar
Re: Shaved Cowl
When you use the vent (Heater Or AC) for fresh air in the cab, this is where it comes from.
KB71C10BBSUPER is offline   Reply With Quote
Old 05-18-2009, 11:44 PM   #4
Hart_Rod
Hart_Rod's Avatar
Re: Shaved Cowl
Yep, what he said.....
Hart_Rod is offline   Reply With Quote
Old 05-19-2009, 12:24 PM   #5
14U2NV
Re: Shaved Cowl
Isn't that where the air from the kick panel vents comes from also?
14U2NV is offline   Reply With Quote
Old 05-19-2009, 12:34 PM   #6
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Shaved Cowl
^^yes.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-19-2009, 04:56 PM   #7
westofb
I really hate wet sanding!
westofb's Avatar
Re: Shaved Cowl
Don't mean to steal this thread, but have a question that goes along these lines. I am planning on buying an after market hvac unit for my project. Do the a.m. hvac use the vent systems on these trucks. I have not ordered one yet still shopping for one, and as far as I can tell they don't. I am thinking if that is the case, I want to weld my cowl vents in (smooth it), and block off the inside vents (maybe use them to hide wiring/ hvac lines.
westofb is offline   Reply With Quote
Old 05-19-2009, 07:44 PM   #8
gator2511
gator2511's Avatar
Re: Shaved Cowl
My Vintage Air system doesn't use the cowl air at all. I'm gonna get a hidden radio antenna and smooth over the cowl. Got my vent doors siliconed shut. I don't use them anyway, just blows hot air in. Vintage air will supply you with a plastic cover to replace the old blower in the cowl air area.
gator2511 is offline   Reply With Quote
Old 05-19-2009, 08:29 PM   #9
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Smile Re: Shaved Cowl
Well, When everything is working as designed, the vents are great. My OLD AIR unit does not use outside air, just recircs inside air. ( same as "max air"" setting on the controls) I kept my vents. The key is to remove the vents and clean out inside the cowl with a shop vac and make sure that the drains arent clogged. You also need the correct weatherstrip for the hood to cowl to make sure that hot engine air isnt coming out at the back of the hood and going into the cowl vents (and into the floor, theres the 'hot air' in the prior post)
The vents are great. days like today it isnt hot enuf for a/c and the floor vents and window vents are great. New cars & trucks just dont have the ventilation like out trucks did- In those if the a/c dosent work, you roast! At least in the classics, you can get a breeze thru the cab (unless you block off the vents)
chuckmc8 is offline   Reply With Quote
Old 05-19-2009, 09:14 PM   #10
Camper Power
Camper Power's Avatar
Re: Shaved Cowl
those kick panel vents are great if your wearing shorts or cruisin down the highway.
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 05-20-2009, 09:20 AM   #11
gator2511
gator2511's Avatar
Re: Shaved Cowl
The hot air I was talking about was just the outside air. When its 90 degrees and 85% humidity outside its hot air coming in the vents! I cleaned out my vents, painted the cowl area to prevent rust, glued down a fiberglass screen over the vent holes in the body under the cowl and put a screen on the back side of the cowl vents. My seal at the back edge of the hood is good but I agree if that was bad or missing you would get a lot of very hot air! My truck is parked under some trees all the time and they are a pain to keep out of the cowl.
Old 05-21-2009, 09:48 AM   #12
Hart_Rod
Hart_Rod's Avatar
Re: Shaved Cowl
I had this done:
Old 05-21-2009, 10:00 AM   #13
Ackattack
Ackattack's Avatar
Re: Shaved Cowl
I got a fiberglass smoothed cowl. It looked great out of the box. I haven't gotten it painted yet. I'm using Old Air A/C system too, so I won't need the vents.
Ackattack is offline   Reply With Quote
Old 05-21-2009, 12:00 PM   #14
70c10
67-72 Addict!
70c10's Avatar
Re: Shaved Cowl
Where did you get the cowl?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-21-2009, 06:40 PM   #15
gator2511
gator2511's Avatar
Re: Shaved Cowl
I'd like to know where you got the fiberglass cowl also.
Old 05-21-2009, 06:44 PM   #16
1moretoy
Re: Shaved Cowl
i got mine from tony gonzalez it looks perfect pm me for his email adress
1moretoy is offline   Reply With Quote
Old 05-21-2009, 09:58 PM   #17
Ackattack
Ackattack's Avatar
Re: Shaved Cowl
same guy here too
Old 05-22-2009, 10:19 AM   #18
NPilot1975
NPilot1975's Avatar
Re: Shaved Cowl
How much was the fiberglass cowl? Has anyone installed it yet to see how it fits?
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 05-08-2011, 05:24 AM   #19
Jeffs70
Jeffs70's Avatar
Re: Shaved Cowl
some great info here... I was wondering about shaving the cowl if it would cause problems with using the vents.
Jeffs70 is offline   Reply With Quote
