05-20-2009, 04:59 PM | #1 |
"something witty here"
VIN decode please
I'm trying to figure out what info is on a vin number for a truck I have, and I have no clue how to decode it. could anyone help please? The vin is KS1401140871. Any help will be greatly apreciated...
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
05-20-2009, 05:05 PM | #2 |
member #16
Re: VIN decode please
Here is a Sample VIN and Model Number for a 69' Chevy Pickup
-------------------------------------------------------------------------------- 1967-1972 VIN Number Codes Example: CE149J 100001 Chassis Designation (1st digit) C= 4x2 K= 4x4 Engine Deisgnation (2nd digit) E = V-8 Gas S = Six Cylinder Gas GVW Range (3rd Digit) 1 = 1/2 Ton 2 = 3/4 Ton 3 = 1 Ton Model Code (4th Digit) 4 = Pickup with Cab and Bed Model Year (5th Digit) 7 = 1967 8 = 1968 9 = 1969 0 = 1970 1 = 1971 2 = 1972 Assembly Plant A = Atlanta B = Baltimore F = Flint J = Janesville N = Norwood P = Pontiac S = St. Louis T = Tarrytown Z = Fremont 1 = Oshawa Vehicle Serial Number 100001 = 1st Unit Built 1967-1972 Model Number Codes (The Model Number is located on the inside of the glove box door.) Example: C E 1 09 9 34 J 100001 Chassis Designation (1st digit) C = 4x2 K = 4x4 P = Forward Control Engine Deisgnation (2nd digit) E = V-8 Gas S = Six Cylinder Gas GVW Range (3rd Digit) 1 = 1/2 Ton 2 = 3/4 Ton 3 = 1 Ton Cab To Axle Dimension (4th Digit) 07 = 42"-47" 09 = 54"-59" 10 = 60"-65" 12 = 72"-77" 13 = 78"-83" 14 = 84"-89" 15 = 90"-95" Model Year (5th Digit) 7 - 1967 8 - 1968 9 - 1969 0 - 1970 1 - 1971 2 - 1972 Body and Brake (6th Digit) 02 = Flat Face Cowl 03 = Cab 04 = Stepside Pickup 05 = Panel 06 = Suburban 09 = Cab, Platform, and Stake Rack 12 = Windshield Cowl 16 = Suburban (Tail and Liftgate) 26 = Custom Suburban (Panel Rear Doors) 34 = Fleetside Pickup 35 = Foward Control (Square Front) 36 = Deluxe Suburban (Panel Rear Doors) 42 = Forward Control Chassis 45 = Forward Control Panel (Round Front) Assembly Plant A = Atlanta B = Baltimore F = Flint J = Janesville N = Norwood P = Pontiac (GM Truck) S = St. Louis T = Tarrytown Z = Fremont 1 = Oshawa, Ont., Can. Vehicle Serial Number 100001 = 1st Unit Built
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
05-20-2009, 05:25 PM | #3 |
Neighborhood Pickle Slinger
VIN KS1401140871
Model Year = 1970 Chassis = 4 Wheel Drive Body Style = Pickup GVWR Range = 3600-5600 Engine = 6-Cylinder Assembly Plant = Flint, MI SequentialNumber = 140871
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
05-20-2009, 06:04 PM | #4 |
you must have used the same search engine, thats the same stats I got for it, but my frame isn't from that year, so how do I tell what year it is?
05-20-2009, 05:17 PM | #5 |
Thanks John, I read it but some reason couldnt really figure mine out, I found a good site that decodes it. Now I just have to figure out how to decode the sn on the frame to find out what year it is. Any suggestions?
05-20-2009, 08:48 PM | #6 |
Not to steal the tread, But my truck's vin makes it a 71 and it's put on with what looks like factory rivits, but from what I read on here it's a 72 cab. Thanks any comments or opinions.
05-20-2009, 09:17 PM | #7 |
Could be the end of the 71 model year frame and they mated it with a 72 cab due to the start up of the 72 model run...this is just a thought.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
