![]() Join Date: Jan 2009
need help
this may be a dumb question here but got to ask; ready to start tearing my frame down to sandblast, just wondering the shims thats on the upper a-arm is this for aliengment? when i paint and reassemble just put back in as they were or what? thanks guys your advice is greatly appreacited
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: need help
Thats the way to do it. Those shims adjust your caster and camber of the alignement. Be sure and keep the stacks seperate and keep track of which stack of shims go on which stud on each side.
Re: need help
thanks tx firefighter
Restoration Virgin!
Re: need help
As TXFirefighter said....keep track of everything.....SO...Be sure to buy plenty of ziploc baggies and a sharpie so you can mark EVERYTHING and bag it...good luck!
I taped my shims together marked the fronts and where they were installed in each individual bags too....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 05-24-2009 at 09:11 PM. |
I am a Referee of life.
Re: need help
Since you will probably be replacing bushings and such as you go back together these are good suggestions.Just to be sure you don't wear tires out have the alignment checked afetr it's all done.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
