Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-24-2009, 10:17 PM   #1
Cyclone44
Step Brother
Cyclone44's Avatar
97 blazer 4.3 fuel problem!
I have a 97 blazer that I just bought for Sharon and if it sits for awhile it just will not start back....If you prime it, it will fire right up....So it's like the fuel is running back into the tank....Is a new fuel pump the answer?
Cyclone44 is offline   Reply With Quote
Old 05-25-2009, 12:26 PM   #2
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: 97 blazer 4.3 fuel problem!
I would check the fuel pressure first. It does sound like the pump or fuel pressure regulator.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 05-25-2009, 12:38 PM   #3
Arad68
Trucks N Tranzams
Arad68's Avatar
Here is a link to the manual on Amazon.
Amazon.com: Haynes Manuals - Chevrolet S-10 &... Amazon.com: Haynes Manuals - Chevrolet S-10 &...
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 05-25-2009, 12:55 PM   #4
Cyclone44
Step Brother
Cyclone44's Avatar
How hard is the fuel preasure regulator to change?....We have a 98 with the same motor in it on our impound lot that has one.....It has been there long enough that it can be parted.....It was running just had all of the glass beat out of it.....
Old 05-25-2009, 12:58 PM   #5
Arad68
Trucks N Tranzams
Arad68's Avatar
Here is a better link.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 05-27-2009, 07:13 PM   #6
Damien
Damien's Avatar
Sounds like a fuel pres. reg. I'm not sure what that one is like to change.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 05-27-2009, 07:47 PM   #7
Cyclone44
Step Brother
Cyclone44's Avatar
Is there any particular reason that you think that is my problem?....Thanks
Old 05-27-2009, 11:32 PM   #8
corn
This looks like it might be worth a try...
http://chevroletforum.com/forum/arch...p/t-12645.html
corn is offline   Reply With Quote
Old 05-28-2009, 08:51 AM   #9
Cyclone44
Step Brother
Cyclone44's Avatar
Thanks Corn, but I do know that it is a fuel problem because you can prime it and it will fire right up....
Old 05-28-2009, 06:51 AM   #10
68C15
blood type; Retumbo
68C15's Avatar
sounds like a fuel volume issue. keep in mind these need at least 58PSI to start. I would have to check on the volume specs but without the $400 tester you have no way to check it. I bought mine from www.fuelsender.com
this is the one I got
http://www.fuelsender.com/fuel_system_analyzer.html
68C15 is offline   Reply With Quote
Old 05-28-2009, 08:53 AM   #11
Cyclone44
Step Brother
Cyclone44's Avatar
Thanks, I really want to put the fuel preasure regulator on it and try that...
Old 05-29-2009, 09:56 PM   #12
Chatterbox71
You better hurry up slacker.
Cyclone44's girl Sharon...
Chatterbox71 is offline   Reply With Quote
Old 05-29-2009, 10:49 PM   #13
Damien
Damien's Avatar
The fuel pressure regulator holds pressure in the line. If the diaphragm leaks, you will have poor fuel economy and a hard start issue if the vehicle sits. If the engine is turned off, it will restart fine. An easy way to check for a bad FPR is to pull the vacuum line off. If there is fuel in the line, its bad.
Old 05-30-2009, 06:53 AM   #14
68C15
blood type; Retumbo
68C15's Avatar
problem is 96 and newer are SCPI meaning the injectors and regulator are mounted inside the upper intake. they don't have a vacuum hose, it gets its reference directly from the area around it. you can generally see them leaking by removing the throttle body and energizing the pump.
BTW, speaking of pumps. these have 2 impellers. one to fill the well and one to create pressure. I diagnose them by using the tester i mentioned before and also with a low amps probe clamped to the power wire. I look at the pump power wave form and check pump speed, current draw, and integrity of the commutator.
