05-27-2009, 09:42 PM | #1 |
PIMPING RIDES
Id this engine
block 9670014 i know they are camel hump heads
1964 CHEVY 1/2 C/10 FLEET 1981 CHEVY 1/2 C/10 FLEET 1995 DODGE 1500 V6 FLEET EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
05-27-2009, 10:07 PM | #2 |
James
Re: Id this engine
This could be it......
1968-76 3970014 350 - - 2 car,truck Many times a number will appear to be another with casting numbers.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end. http://viewmorepics.myspace.com/inde...lbumId=1709080 http://s258.photobucket.com/albums/h...e_top_view_all |
05-27-2009, 10:10 PM | #3 |
James
Re: Id this engine
Another find.....
1970-73, 3970014, 350ci, hp/low200 hp/high300, main2/4, LA built Camaro
05-27-2009, 10:13 PM | #4 |
James
Re: Id this engine
Do you happen to have a suffix code to go by? I may be able to narrow it down for you.
05-27-2009, 10:18 PM | #5 |
PIMPING RIDES
Re: Id this engine
but it is stamped 9670014
05-27-2009, 10:22 PM | #6 |
James
Re: Id this engine
Well, If that is the actual number then I dont know what to tell ya. I couldn't find it anywhere.
05-28-2009, 12:35 AM | #7 |
60-66 Nut
Re: Id this engine
Larry, see if you can find the numbers and letters stamped on the pad just in front of the passenger side head.
05-28-2009, 12:49 AM | #8 |
Resistance is Futile
Re: Id this engine
That intake is definitely older....the oil filler tubes were gone long before the 70's IIRC. No accessory bolt holes on the heads make them pre-68/69. Doesnt really ID the engine.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-28-2009, 11:37 PM | #9 |
Re: Id this engine
check out this chart for SBC bore and stroke
http://www.aces.edu/~parmega/sbc.html says the 327 and 350 share the same 4 inch bore...
CHEVY ONLY Last edited by joe231; 05-28-2009 at 11:39 PM. |
05-28-2009, 11:53 PM | #10 | ||
60-66 Nut
Re: Id this engine
05-28-2009, 11:54 PM | #11 |
Re: Id this engine
Sorry John...I missed that little tidbit in your post
CHEVY ONLY |
05-29-2009, 12:10 AM | #12 |
60-66 Nut
Re: Id this engine
No problem.......
