Old 05-30-2009, 10:52 AM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
getting rally wheels that need painting..
found 4 15/8 rally wheels 5 lug that need sandblasting and painting, whats the color called, the silver looking color?
should i spraybomb them, or spend the extra $ and do it right, how much would paint/primer be for them, where can i get it at, and how much do i need?
can i sandblast the wheels with tires already on them or no?
and does $100 sound like a deal, or no deal for the wheels, this is MAYBE with caps included...
Thanks!!!
John
1999 Toyota Tacoma 4x4
Old 05-30-2009, 10:59 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: getting rally wheels that need painting..
The color is argent silver... asa far as price, depends of the condition of the tires. they go for about 20 each with rings around here
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-30-2009, 11:07 AM   #3
oldblue1968chevy
guy wants 25 apiece with no tires i need to get something that ima keep on the frontend before i take it to get an alignment lol i can paint em later, (preferb. with the tires on too)
John
Old 05-30-2009, 11:11 AM   #4
mr48chev
mr48chev's Avatar
It's hard to paint them right with the tires on the wheels.
100 might not be out of line if all the caps and rings are close to perfect. I don't know what they go for around here but the 20/25 price range is probably close.
Lately though anything that can be called "Rally" seems to comand a stiff price.
Old 05-30-2009, 11:52 AM   #5
oldblue1968chevy
im not sure if i got 15x7 or 15x8 front wheels....if i have 15x7 wheels..will my tires that i already havfe fit the wider 15/8 wheels? thanks
John
Old 05-30-2009, 11:57 AM   #6
dan42
dan42's Avatar
Need to know the tire size, then there are charts you can check on the different tire sites.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-30-2009, 12:31 PM   #7
big_al_71
big_al_71's Avatar
$100.00 is a very good deal around here...I would strip the paint, primer them then spray paint...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-30-2009, 03:21 PM   #8
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
$ 125 for five. The caps & trim rings were scrounged & cheap. The narrow (van) trim rings are very slightly mis-matched on the right & left side of the truck, but nobody but me seems to ever see it.
No sandblaster available at the time that I wanted to roll with them, & no argent silver at O'Reilly's, so it was wire brush on an electric drill, wipe clean with thinner, & WalMart rattle can silver. Two days hardening time & the new tires went on.
Definitely they're "wrong" compared to being truly correct, but these wheels never came on these trucks anyhow !!! Grandad always said: "Boy, poor folks like us has poor ways."
Several years later, they still look pretty good, and the shiny silver has faded a bit to look a lot more argent-like.
68shortstep is offline   Reply With Quote
Old 05-30-2009, 04:19 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I paid $150.00 with caps and rings.I didn't want to use a silver so painted mine Metallic Charcoal.The rings are in great shape the caps are ok but I don't like the 4X4 caps.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-30-2009, 05:02 PM   #10
70k52wd
Blaze-Air
70k52wd's Avatar
Just wire brush with a drill attachment. Get the crud off. Sand them with 150-220 to get all the imperfections blended out, prime gray, sand with 800. Wash the rims with light soapy solution. Rinse very well. Make sure ALL moisture is gone. Paint. Go light first coat. I like to lay a heavy second coat. 3rd coat if necessary. Done. Clear if you like.
FYI. I just painted a set with plasti-kote argent silver p/n 621. I had a can of aluminum paint also. I can't tell the difference. I feel the argent although correct, is too bright. I wound up using plasti-kote steel, p/n 618. It's a shade or two darker and trim rings and center caps contrast well.
70k52wd is offline   Reply With Quote
Old 05-30-2009, 08:50 PM   #11
big mike71
big mike71's Avatar
I sanded mine, primed them and painted them with metalic silver, I know it's not the factory color but I like it.
big mike71 is offline   Reply With Quote
Old 05-31-2009, 03:09 PM   #12
dan42
dan42's Avatar
I like those caps - where did you get them?
Philippians 4: 6-7
Old 05-31-2009, 06:31 PM   #13
big mike71
big mike71's Avatar
They came with the truck I thought L M C had them but I didn't see them in the catalog. Year one has them for camaros I think they will work for $220 a set. If lived by tx firefighter I would have mine powder coated.
Old 05-31-2009, 11:13 PM   #14
chevy_mike
Never Ending Projects
chevy_mike's Avatar
The reason you didn't see them is that your rally's are car rally wheels, done by an aftermarket company. GM never made this style of rally for the trucks. Your center cap is the same they used on GM cars like Camaro's, Impala's, etc. They look great, especially on trucks but they are not truck rally's like the other ones being posted.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-30-2009, 10:02 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I highly recomend NOT going with chemical stripper. Sand blast them, sand them by hand, wire wheel them... but no chemicals.
Old 05-30-2009, 10:39 PM   #16
Hoffman65burb
Hoffman65burb's Avatar
Here are mine. I just used aluminum silver enamle with a couple coats of clear. Wouldent suggest using aluminum silver unless your clear coating it, without clear coat they just look cheap
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 05-30-2009, 11:45 PM   #17
oldblue1968chevy
tires on my 68 are 235/?/15 the wheels i need to put them on are either 15/8 15/7 my choice...some wheels are greyish, some are white lol
John
Old 05-30-2009, 11:46 PM   #18
oldblue1968chevy
oh and can i get a color in rattlecan close to the argent silver, and do you guys recommend clearcoating the wheels? can i get spraybomb clearrcoat
John
Old 05-30-2009, 11:57 PM   #19
70k52wd
Blaze-Air
70k52wd's Avatar
I think these questions were answered already. Spray can clear is available also. Check the rack you get the paint from.
Old 05-31-2009, 08:30 AM   #20
weasel29gm
SLOW BUT SURE,BUT CLOSER
Clean em' and paint em'!!! All you see is the middle with caps and rings. I tend to laugh when I see or read about blasted and p/coated ralleys. Over done and over spent for a $25 wheel IMO.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 05-31-2009, 09:07 AM   #21
fishingjred73
fishingjred73's Avatar
Mine are painted same color as truck
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 05-31-2009, 09:50 AM   #22
matchstick
matchstick's Avatar
Autozone has a silver wheel paint that's very close.
matchstick is offline   Reply With Quote
Old 05-31-2009, 10:33 AM   #23
oldblue1968chevy
so should i wirewheel the paint off or sandblast? id like to sandblast a bumper too
John
Old 05-31-2009, 11:18 AM   #24
fishingjred73
If their not scratched and scarred up real bad take a scotch brite pad and mix up some soapy water (we use to use spic n' span powder) and scrub them real good. That's all I did to mine and they still look good after 17 years(when they're clean lol).
James
Member of
Old 05-31-2009, 12:09 PM   #25
oldblue1968chevy
there pretty bad from what i remember lol, 1 or 2 are white lol
heres the plan:
wake up
go to bank
return swirly wheel back to dude (i was gonna buy these, "dylan" on here has some)
schedule an alignment
get rally wheels (not sure if i get fronts or front/rear)
get my old rallys/tires and put the tires on my 5 lug wheels...
have tireplace put 5lugrallys/old 6 lug rallystires on my blue truck
drive home happy with matching wheels then see about a 5 lug reraend lol
oh and get paint or paintandsand
John
