100% gearhead
I need your guys' support please.
Most of you have seen the pink (I still don't know the factory name for the color) '63 GMC I drive. Recently it has been declining in the running department. It all started when the Air Zenith compressor took a dump. Then the Viair took a dump. After that the electrical to the compressor caught the truck on fire three times in one week. Then the motor developed an intermittent miss under load and then started missing more frequently. Last week it dropped a cylinder, caught fire pretty bad (fourth one!) and now it hits on all eight but loses cylinders at idle. It runs so rough that it won't idle period. The mill has less than 20,000 miles on it too! Some buddies had to wrestle the gas can away from me this weekend as I was going to simply torch the thing up and watch it burn. That would be a shame though as this truck doesn't even have 47,000 miles on it. Wanna help lift my spirits here?
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. Last edited by Imperial Kustom; 05-31-2009 at 11:10 PM. |
Re: I need your guys' support please.
Haha. Dont know where to start...
Just walk away. It will be easier once you've taken a step back. That helped huh?? ![]()
Tim Road Hounds |
100% gearhead
It's my daily driver though.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
I feel your pain and frustration....but it will get better....How is that for some motivational speaking?
![]() stare into my avatar and the world will be right again..........
![]() ![]() Last edited by joe231; 05-31-2009 at 11:17 PM. |
1 thing at a time is progress.
Since you can't step away from it cuz it's your daily driver, go buy another truck and choose the lesser of the 2 evils to be the daily driver. Then fix the one you don't drive. just my .02
Alan
Philippians 2:14-16 |
HOW long until spring??
![]() Join Date: Mar 2009
If you have fires it sounds like electrical issues. Maybe old or undersized gauge wiring to compressor or other added loads? Does the battery stay charged? Is the alternator large enough? Check fusing. Fuses properly sized should open the fault before a fire occurs. Low voltage or alternator problems could cause weak spark at idle. Like Grumpy said --step back and think first --Sleep on it
It will be simple once you find the problem -- good luck
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
How is the vacuum? any melted/ leaking hoses?
Registerd User
What motor is it? When sparkplugs get fuel soaked they will act like what you are saying. How did #4 catch fire? You talkin about plug wire? Need more info. Is it running ritch? Old distributer? Fuel in motor oil?
I wish I could say something enlighting like the other guys, but they have covered the bases already.
However, maybe it's so low to the ground that the earths magnetic force is affecting the coil emmisions and the comm's systems is overloaded? ![]()
http://s1299.photobucket.com/user/jb...23904108567829 |
1961 crewcab
I know the feeling... I thought I smoked the cam in my 65, I was trying to figure out where and how to get another motor or chang the cam....
then a friend listened to it and mentioned that it was just a broken spring on the fuel pump ![]() you can just air up your bags to ride hieght and leave them can't you? the sbc might be smoked.. but luckily they are one of the cheapest of any engine choice you could have. might be easy enough to put a cheap runner in it if you can source one. ***you have probably thought of this.. but carry a fire extinguisher!*** Last edited by jonzcustomshop; 06-01-2009 at 08:33 AM. Reason: missing a lower case "t" |
Resistance is Futile
I think its time for a wiring harness upgrade. You oughta be able to thrash it in there in about 2 hours judging by how fast you got the truck done
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
100% gearhead
I got off work a little early today, went to the DMV, and registered my '97 Sonoma. Daily driver problem solved. I also pulled a new ignition module out of my stash-o-parts, so we'll see what happens. As for the first three fires, all were caused by a faulty switch to the compressor, which has an inline 40 amp fuse and a relay. The fourth was because the starter is taking a dump. I went to crank the truck over and the starter drew WAY too much on the system and smoked all the underhood wiring. New starter will be here tonight. I put a new harness in and yes, it did take about two hours!
Watch out for your cornhole !
![]() Join Date: Jun 2003
If your wiring is catching fire, your fuse is mis-sized for the wire gauge. It's that simple, the fuse should be matched to the wire size. Apparently, whatever size of wire you are running is not rated to carry 40 amps. You need either a bigger wire or a smaller fuse.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 06-01-2009 at 06:58 PM. |
#14 | |
#15 |
100% gearhead
oh. The alternator is 65 amp.
#16 |
100% gearhead
yeah. the fuse is between the compressors and the switch, Terrible place, I know. But I did figure out my miss. Apparently the power lead to the HEI wasn't carrying a full 12 volts. Rewired it and I'm good to go! Just waiting on the starter and blanket now and all systems should be go and I should be back in reliabilityville!!!! Thanks guys for all your support and input during my emo moment. That's why I love this site!
#17 |
it may be a pain now, but i love the feeling when I drive by some one in a nice NEW ride and get the thumbs up!!! way too many good times will come for you hang in there
#18 |
On coil/points distributors there was a resister wire in the harness which dropped the voltage down to save the points. The starter had a set of contacts which closed and sent full voltage to the coil only while the starter is engaged. Moral of the story-If you install a HEI-- find and remove the resister wire and replace it. Glad you are progressing-- Imperial Kustom We have not met yet but I passed you the other day on Chinden. Truck looked good.It was not on fire at the time!!!
#19 |
100% gearhead
Thanks guys! Up 'til now, this truck has been super reliable, and the '62 was as well before I pulled it off the road. The compressor cable is indeed 6 gauge wire! It's a fat mother faker!!! Hopefully the new starter with a heat blanket will solve my woes as far as that goes and I can go back to worry free cruising, which I do a LOT! This stupid thing gets better than 400 miles to a tank, so I drive the wheels off it! Thanks for the compliment Bubba! Can't wait to meet ya in person one-o-these days. And feel free to call me Cameron.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. Last edited by Imperial Kustom; 06-02-2009 at 02:55 PM. |
#20 |
just post up some pics from it's hay day and let us all stare at them
#21 |
100% gearhead
Its already in its heyday. She's back up and runnin like a champ as she always does!
#22 |
where are the pics then???
#23 |
KOFFIN DRAGGER
Joe, askin for pix, never!
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
#24 |
#25 |
100% gearhead
Theyve been posted on here before, but I know you guys still need your fix!! It's got a front bumper on it now too...
